TTL-232R converter
matt_hau
Is there anywhere in Australia where I can buy a TTL-232R USB cable?I know you can get them from FTDI or mouser but you pay $30USD freight on a $10 cable.
I am building a Motorbike ECU interface and apparently this is the silver bullett.
I am not an electronics wizz but I am getting all my info from
Thanks in advance. :)
Ebay is a good source for USB to RS232 converters.
It is quite a simple project to make an RS232 - TTL converter, based on a MAX232 or similar.
The only danger is that some USB to RS232 converters do not work with all software/hardware that does work with a real RS232 port on a desktop PC. As your application only uses Rx and Tx you should be OK.
Dontronics will have the ftdi cables that you are after!
He is in australia.
Cheers
Stolzie
