Trying to understand USB protocol
graemeian
I purchased the Oshnsoft PIC16 software for USB.
The sample is as follows:
Define CLOCK_FREQUENCY = 16
Define CONFIG1 = 0x0f84
Define CONFIG2 = 0x1def
OSCCON = 0x3c 'intosc=16mhz
UsbSetVendorId 0x1234
UsbSetProductId 0x1234
UsbSetVersionNumber 0x1122
UsbSetManufacturerString "OshonSoft.com"
UsbSetProductString "Generic USB HID Device"
UsbSetSerialNumberString "1111111111"
UsbOnIoInGosub usbonioin
UsbOnIoOutGosub usbonioout
UsbOnFtInGosub usbonftin
UsbOnFtOutGosub usbonftout
AllDigital
ANSELA.4 = 1
TRISC = 0
PORTC = 0xff
UsbStart
PORTC = 0
Dim an3 As Byte
loop:
Adcin 3, an3
If an3 < 50 Then
PORTC = 0
UsbStop
While an3 < 100
Adcin 3, an3
Wend
PORTC = 0xff
UsbStart
PORTC = 0
Endif
UsbService
Goto loop
End
usbonftout:
Toggle PORTC.0
Return
usbonftin:
UsbFtBuffer(0) = UsbFtBuffer(0) - 1
UsbFtBuffer(1) = UsbFtBuffer(1) - 1
UsbFtBuffer(2) = UsbFtBuffer(2) - 1
UsbFtBuffer(3) = UsbFtBuffer(3) - 1
UsbFtBuffer(4) = UsbFtBuffer(4) - 1
UsbFtBuffer(5) = UsbFtBuffer(5) - 1
UsbFtBuffer(6) = UsbFtBuffer(6) - 1
UsbFtBuffer(7) = UsbFtBuffer(7) - 1
Return
usbonioout:
Toggle PORTC.1
Return
usbonioin:
UsbIoBuffer(0) = UsbIoBuffer(0) + 1
UsbIoBuffer(1) = UsbIoBuffer(1) + 1
UsbIoBuffer(2) = UsbIoBuffer(2) + 1
UsbIoBuffer(3) = UsbIoBuffer(3) + 1
UsbIoBuffer(4) = UsbIoBuffer(4) + 1
UsbIoBuffer(5) = UsbIoBuffer(5) + 1
UsbIoBuffer(6) = UsbIoBuffer(6) + 1
UsbIoBuffer(7) = UsbIoBuffer(7) + 1
Return
I am having some trouble with the logic.
When the program runs, it cycles through the loop statement.
I do not understand how to get data to and from the PC.
It looks like these statements get used only once at the beginning
I see that USB start and service are in the main loop. However, I do not seem to understand the logic.
It looks like
will call the usbonioout subroutine and what is ever in the subroutine will pass out of the USB port?
If that is the case, can I pass more than a bit through the USB port?
I am using PIC16F1459.
Would someone please provide an explanation of the logic?
Thank you.
UsbService
This does all as necessary..
If you load the feature buffer and the io buffer full 'o' bytes... The PC program receives said bytes you can then send the two buffers back to the pic!!!
The functions
are just function declarations....
Just call usbonioout and usbonftout after you filled them!!
usbonftin and usbonioin read the PC -> pic transitions...
Thank you Ian. You got me started but now I am still confused. I wrote the following code:
I expect to get an3 incremented by one but instead the incremental amount is 5.
I am using Jan's vb.net program.
Help.
UsbOnIoInGosub input_report_before_sending
UsbOnIoOutGosub output_report_received
UsbOnFtInGosub feature_report_before_sending
UsbOnFtOutGosub feature_report_received
AllDigital
TRISC = 32 '100000
Dim an3 As Byte
UsbStart
loop:
an3 = an3 + 1
WaitMs 100
UsbIoBuffer(3) = an3
UsbIoBuffer(4) = an3
UsbService
Goto loop
End
feature_report_received:
Toggle PORTC.0
WaitMs 100
Return
feature_report_before_sending:
Return
output_report_received:
Toggle PORTC.1
WaitMs 100
Return
input_report_before_sending:
Return
you need a "ping pong " type of communication.... Use the PC to "Request" the packets..
If your transfer is slower than the pic ( 5 times slower it would seem ) then your result is understandable...
Increase the AN3 value inside the feature received function... It should work as expected!!
Toggle PORTC.0
AN3 = AN3 +1
WaitMs 100
Return
Thank you for the demo. I can now send and receive data to and from the PC using USB but I cannot do much else as the USB protocol locks out other activity.
Here is an example: I am trying to receive data through a serial port and when the PC prompts, the received bytes will pass through the USB port to the PC.
The PC should receive 0 to 8 bytes.
If I put UsbStart in the loop, PORTC.1 never toggles.
Without UsbStart in the loop, I cannot connect to PC using Eric's VB program or Jan's.
What is incorrect with this software/function protocol?
Dim i as Byte
Dim x(8) as Byte
i = 0
UsbStart
loop:
'This program needs to wait for some bytes to be received through the serial port .
'The PIC16F1459 will respond to a PC call to send the data through the USB port.
'set up PIC chip to receive data through serial port
'Wait for receive register to get a byte from serial port (portc.5)
If PIR1.RCIF = 1 Then ' Is this correct? Otherwise, how do I use these?
Define SERIN_TIMEOUT_REG = INTCON
Define SERIN_TIMEOUT_BIT = T0IF
Serin PORTC.5, 9600, x(i)
WaitMs 10
i = i + 1
If i = 8 then i = 0 '
Endif
UsbService
Toggle PORTC.1 '
WaitMs 50
Toggle PORTC. 1' I have an LED attached and I want to see it blink to confirm the loop
WaitMs 50
Goto loop
Thanks in advance..
Regards
hi gra'
If you post your full program listing [ as a post attachment] I will run it in my system, see if I can locate the problem.
E
EDIT:
Please confirm the PIC type, the IDE says a 16F1459 does not have USB support.??
Eric,
Thank you very much. Attached is the code.
I saw that also but I thought it was a typo as it lists all of the chips with an asterisk. I am using PIC16 Simulator with basic and a few other options. On the web, the creator is listing a sample USB code for the 16f1459 chip.
I have attached a sample code that does send bytes to the PC via USB. However, I cannot get it to receive bytes through PORTC.5( the RX port) . I am using the PIC low count USB board where LEDs are connected to ports C 0-3.
Please review my code and see why I cannot read the serial port. I am using a square wave output from my o-scope in the hopes that I would get some random byte values as the PIC does not appear to have parity check. I had good luck with Serout as I output a string of "U"s to get sections of square waves.
Regards.
G
  • LOCUSB.bas
hi.
Downloaded your code OK.
I will try to reply in next 24 hrs. [its late evening here]
E
At what time interval are you receiving data on the RXD input line.?
If the calling UsbService interval is longer than one second you will have a problem.
Have you considered the UsbStop command.?
Extract from the OSH Manual.
UsbService statement should be executed as often as possible,
because several calls to UsbService routine are necessary to process each of the USB events.
The firmware will work correctly even if you execute UsbService only once per second.
E
EDIT:
Why are you using a software UART on RC5 rather than the hardware UART on RB5.?
Clip from your Code:
INTCON.GIE = 1 'this enables global interrupts
If PIR1.RCIF = 1 Then 'you are waiting for a hardware RXD intr.??
'but you have not Enabled the RCIE for the hardware Uart.??
'you are not using the hardware Uart
WaitMs 10
i = i + 1
If i = 5 Then i = 0
Endif
hi gra'
I see why you have been forced to use Serin, its because Oshonsoft does not support the hardware UART.
I have come to the conclusion that the supposed upgrades to the Oshonsoft PIC list are a load of hooey.!:mad:
Over the past 12 months I have run into problem after problem with other later PIC's that do not have support for this or that feature.:banghead:
All my debug reports regarding the shortcomings of this IDE, except for one, have been ignored, I was advised to fix a compiler problem by adding more decoupling caps.!!
Eric
How do you want to proceed.?
E,
Thanks for your help. The RCIE was an oversight as I am mixing Serin and RCREG . The final design will remove the waitMS for the portc3 Toggle.
Here is another version. I have a sister PIC piping data to portc.5 of this PIC16f1459. I am not seeing data change on the HID bytes.
Do you see any blatant errors in this new version?
D
  • LOC1459.bas
hi D.
At what time interval are you receiving data on the RXD input line, then transmitting to the PC using USB..?
eg: if its a greater period than 1 second so that the UsbService call interval is greater than 1 second, you will have a problem.
E
The PIC16f1459 will need to wait as much as a day for the serial data. This PIC will input serial and output USB when an activity occurs. Eight bytes of serial data will be be received through RX. Software from a PC will be polling the USB port looking for data from the PIC. The polling interval will be about every 5 seconds.
