theSovereign
Howdy folks, I hope this is the right forum for my post, and hopefully someone can help me figure this out -- if it is at all possible.
I've done some console modding in the past, installed carPCs in a couple of cars, done a bit of soldering here and there, and I have alot of interest in electronics, but unfortunately I'm pretty clueless when it comes down to the nitty gritty of electronics.
Ok, so finally, here is the reason for my post:
I have a **broken link removed**, which serves either as a Bluetooth transmitter or receiver. I will be using it as a receiver in the car, plugged into the aux-in of my headunit so I can play audio from my phone wirelessly via A2DP.
The HWS-BTA2W will be connected to a switched auxiliary power outlet in the car, so it will be turned on when the engine is running, and off when the engine is off. Unfortunately the HWS-BTA2W does not automatically turn on when the unit receives power, and requires the power button to be pressed.
The power button functions as follows: If the unit is off, press briefly to turn it on. If the unit is on, if pressed briefly it does nothing, but if held down a little longer, it turns the unit off.
What I'd like to do is mod it so that it automatically turns on when it is receiving power, this way it'll save me a step when I get in the car, and I can also "bury" the unit in the dash.
Unfortunately I don't have a schematic for it, but I did take some fairly decent photos of the front and back of the PCB, which I hope might be helpful. I can provide higher resolution photos / PSD if needed.
The key to the numbering is as follows:
1 - Power button
2 - Pairing button
3 - Transmit / receive mode selector switch
4 - Power input
5 - Line out
6 - Line in
I forgot to label the LEDs, but the top one is the Power indicator LED, the bottom one is the Bluetooth connectivity inducator.
In any case I hope this isn't an impossible feat and thanks for your time!
1 - Power button
2 - Pairing button
4 - Power input
5 - Line out
6 - Line in
