Triggering a mosfet with Proteus
pabloncho
Hello,
I'm trying to drive a mosfet with a 5v 100kz pulse, but I can't activate it. Does somebody know what am I doing wrong ?
Just checking, you do realize when the MOSFET is switched on, that it's just shorting it out, right? You're not going to get any current to the right of it.
Hi
Nice remark, I tried placing a resistance between the mosfet and the ground, but the mosfet is still off. If I replace the mosfet by a bipolar it works perfectly...uu
Remove R2, I don't think it is really serving much of a purpose there. Also, 10k for R5 seems quite high. Try exchanging it for, say, 4.7k, or even 2.2k. I just pulled these values out of mid-air, no math went into finding those values.
EDIT: I almost think you can take out R5 completely.
Is the signal on the bipolar transistor supposed to be inverted? The way you're triggering the FET now, it will switch on when the signal on the BJT is switched off.
Furthermore, the components to the right of the FET are connected directly between +5v and ground, meaning they will always be supplied with current. The 1 ohm resistor is going to take most of the current. Are you trying to switch on current to the components to the right of the FET? If so, you're taking a completely wrong approach.
The 2N6660 Mosfet is very old and is obsolete so maybe your SIM program knows nothing about it.
The circuit you showed is a voltage booster that should have a continuous input from an oscillator, not just one pulse.
I wonder why the NPN transistor has an emitter resistor that prevents the Mosfet from completely turning off.
Is the load actually only 1 ohm as shown by R1? Then the little old Mosfet is overloaded because its on resistance is 200 times higher than a modern Mosfet.
In my experience, if Proteus doesn't have simulation information for a part, it will let you know and you will be unable to run the simulation. Therefore, I don't think this is the problem.
The symbol used in the above schematic can sometimes represent a repeated pulse. I agree though, a square wave would definitely be a better idea.
I was wondering the same thing.
To the OP:
Where did you get this circuit from? There are all sorts of problems with it, and I'm not seeing how it's supposed to work. Please show us what you used for reference.
I'll show you the basic circuit that I want to made. Is a dc-dc boost 1.2V - 5V to 12Vout, 100W out. The bipolar was for making a drive for the mosfet, and as you said, placing R2 wasn't a good idea. My main problem is that I can't activate the mosfet.
The pulse that I'm sending is a periodic signal !
For the source, you can see this page https://www.ti.com/lit/an/slva372c/slva372c.pdf
You can remove R2 & R5, then put 10k in the base to limit the base current.
Thanks for the calculator. What mosfet shall I use then? It's incredibe hard to pick the good one :confused:
As I said before, if I use a generic npn bipolar instead, it works fine, but even if I try with a generic nmosfet it doesn't work. I also tried with a 10V amplitud pulse, but it seems it doesn't wants to be activated. So I think my problem is that I dont know how to trigger the mosfet (?)
There are hundreds of modern Mosfets that have a very low on resistance when the gate-source voltage is only 4.5V. Try an IRF3711.
Try a square wave 5V or 10V peak signal as the input.
Your inductor has no "H" for its value in Henries. Then maybe your SIM program sees it as a very low value resistor.
Why did you add a resistor in series with the source pin of the Mosfet?
I think that was probably my fault, I pointed out that when the FET was switched on, it was almost a dead short. However, I had overlooked the inductor at that point. A 1-ohm resistor really doesn't make much of a difference either way, but it should definitely be removed.
I don't really understand why the OP is using a BJT to switch the FET instead of controlling the FET directly....?
I simplified the schema (see my last post pls), now I send the pulse directly to the FET.
That's what I did, but still I can't activate de mosfet. I tried with the IRF3711 fet, and also with a generic one.
Did you ensure the FET drive signal pulse is repeated, as AG pointed out? Or is it just a single pulse?
I don't use Proteus, but here is spice.
I vaguely remember having problems with just using signal sources to drive transistors in Proteus. It's possible that's what's happening to yours. Try replacing the signal source with a push-button connected between the gate and +5v, and a resistor (say, 10k) between the gate and ground. Then operate the pushbutton and see if the FET switches.
Ronv, that's exactly what I'm searching for ! But still can't get it Uu, and I dont have spice
DerStrom8, I tried this:
Do you see that the FET is not activated? Even if I connect it directly to the 5V source ! I also tried placing a button, and I get this error:
DELMIN increased to 2.2e-16 due to lack of time precision
transient GMIN stepping at time 1.2
TRAN: Timestep too small, timestep=2.77e-16: trouble with instance D1
The load is only 1 ohm and the Mosfet is an old one. When the Mosfet switches then the voltage boost will not be much.
I'm kind of guessing, but it looks like maybe your inductor has very low resistance so 264 amps thru the fet. Since it can't do that it may show 5 volts still. Try it with a resistor - say 1 ohm in place of the inductor until you can see it switch.
