Trigger 220vac relay using pic16f627a
JeanTech
Hi there
I would like to know if anyone has a circuit diagram that can trigger a 220vac relay using the 5v from the pic16f627a.
Thanks in advance
JeanTech
Hi there
Thanks in advance
JeanTech
Look at this device.:)
Thank you very much Eric, this article was really helpful and much appreciated. I'm a little new to electronics and I would like to know if this optoisolator can trigger this TRIAC: "bt136_600e". Will it be possible to use the same circuit suggested in the datasheet?
Thanks in advance
JeanTech
Thanks in advance
JeanTech
The BT136 looks OK.
The MOC3081 series should be able to trigger pretty well any triac. Figure 8 on the data sheet is the standard circuit
