Tremolo control - input signal seems to be riding the output
atferrari
Most Helpful Member
LTSPICE - .asc file, model and sub attached.
In this basic tremolo control, I cannot avoid what seems to be the input signal riding the output.
As is, even if the JFet is cut (??) I still get the equivalent of the input signal, at the output.
Sure it is more than 100% modulation; done on purpose to put in evidence that the JFet is cut.
Around this for many hours, I supose I am wrongly biasing the opamp but cannot see where or how.
Comments will be appreciated.
  • J310.model.txt
  • TL072.sub.txt
  • Tremolo 03 con JFET.asc.txt
What exactly do you want the output to look like?
As the FET is configured the U2 op amp gain can vary from 1 (follower) to about 6.3 with the FET going from off to full conduction.
It doesn't sound like that's what you wanted.
Edit: If you want the output to go full-off then add a 10kΩ resistor in series with the + input to U2 and connect the drain of J1 to the junction of that resistor and the + input.
Connect R5 to Vref.
Connect R5 to Vref.
My bad; at a certain point is a voltage follower. Yes!
I want the output following the modulation imposed by the signal at the gate, as you say, output full-off.
Not sure I understand your proposed changes (much less why). I will try to work it out.
Gracias Carl!
/Edit to add:
No time yet to play with LTSpice but what you are suggesting is to stop messing with the gain setting and implementing an attenuator for the input. Am I right?
Edit/
I want the output following the modulation imposed by the signal at the gate, as you say, output full-off. :confused:
Having an output gain of one as stated in your first sentence doesn't seem compatible with your second requirement of the "output full-off".
My change in the circuit was to allow reducing the signal gain to zero to get that full-off.
