Transistor Characteristic curves
Nethra
I am trying to get the VI curves of the BC 107 NPN transistor, in common emitter configuration.
I face two issues:
1) Input characteristics :The base current is linearly increasing with the base emitter voltage , which is not the actual case seen in the model graph.(Vce was fixed)
2) Output characteristics: There is no flow of collector current even with increase in the collector emitter voltage.( Base current was fixed to a particular value)
I need some help to rectify the errors. Please do suggest an alternative method if any.
Please show your circuit.
How are you getting your results. (SPICE or bread board)
Do you have a emitter resistor to ground.
Base current=? Emitter current=? Collector current=?
I face two issues:
Hi Nethra,
As you imply there is something wrong with your test jig. Would you like to post a schematic showing the circuit of you test jig.
Or would you jut like one of us to post a suitable circuit?
spec
(same thoughts again Ron:joyful:)
POST ISSUE 2 of 2017_02_01
Hi again Nethra,
below is a sketch showing a suitable small signal NPN BJT DC test jig. Just reverse the power lines to test a PNP BJT.
A nice touch would be to make RV1 a ten-turn potentiometer.
spec
Hi Spec,
Isn't your transistor testy jig designed for a power transistor on a heatsink?
With a 12V supply the poor little transistor will saturate with a collector current approaching 1.2A! If the trimpot is turned down so the transistor is linear then it will melt when it dissipates 3.6W!
hi Spec,
We don't know much!
I think the voltage is measured from (A) to ground and not B-E. This error will make the current be linear as described.
Maybe the E and C are wrong. Common mistake. Maybe the transistor is damaged. Common.
Hi Spec,
Thanks AG,
That's what happens when I do not pay attention.:banghead:
spec
(schematic of post #4 now updated)
hi Spec,
We don't know much!
Hi Ron,
Yea, looks like something like that. It may seem odd to us that there could be a problem measuring the parameters of a BJT but, as you can see from AG's post #5, I made a cock of it, and looking back to my first adventures with transistors (OC71, OC44) I had a few disasters.:eek:
spec
Thank you all.. but then I am sure that the transistor is working fine and the emitter and collector are placed correctly.
I am using a bread board circuit. The emitter is grounded directly.
I think you burned out the poor little 50 years old transistor and now its base-emitter is just a piece of carbon resistance.
The datasheet for the old BC107 says its maximum allowed continuous collector current is only 100mA but with your 100 ohm collector resistor then with a 30V supply the maximum current is 295mA.
The datasheet has a graph showing that with a collector current of 10μA the typical base-emitter voltage is 510mV, with 100μA the voltage is 545mV, with 1mA the voltage is 0.6V, with 10mA the voltage is 675mA and with 100mA the voltage is 760mA which are non-linear like a silicon diode.
Of course the base-emitter voltage drops as the transistor heats up.
