Tool chains For the STM32F4
I might quit this and use there Header file i found that all this stuff is defined but in the bottom half of header:
EX:
#define  RCC_AHB1RSTR_GPIOARST               ((uint32_t)0x00000001)
#define  RCC_AHB1RSTR_GPIOBRST               ((uint32_t)0x00000002)
#define  RCC_AHB1RSTR_GPIOCRST               ((uint32_t)0x00000004)
#define  RCC_AHB1RSTR_GPIODRST               ((uint32_t)0x00000008)
#define  RCC_AHB1RSTR_GPIOERST               ((uint32_t)0x00000010)
#define  RCC_AHB1RSTR_GPIOFRST               ((uint32_t)0x00000020)
#define  RCC_AHB1RSTR_GPIOGRST               ((uint32_t)0x00000040)
#define  RCC_AHB1RSTR_GPIOHRST               ((uint32_t)0x00000080)
#define  RCC_AHB1RSTR_GPIOIRST               ((uint32_t)0x00000100)
#define  RCC_AHB1RSTR_CRCRST                 ((uint32_t)0x00001000)
#define  RCC_AHB1RSTR_DMA1RST                ((uint32_t)0x00200000)
#define  RCC_AHB1RSTR_DMA2RST                ((uint32_t)0x00400000)
#define  RCC_AHB1RSTR_ETHMACRST              ((uint32_t)0x02000000)
#define  RCC_AHB1RSTR_OTGHRST                ((uint32_t)0x10000000)
Ok new code using there header:
#include "stm32f4xx.h"    //Include main header for MCU
#define LED1 0x1000
#define LED2 0x2000
#define LED3 0x4000
#define LED4 0x8000
void delay(int ticks);    //Used for delays
void main()
  //Bits 1:0 (01) HSE oscillator selected as system clock
  RCC->CFGR = RCC_CFGR_SW_HSE;
  //Bit 3 GPIODEN: IO port D clock enable (1: IO port D clock enabled)
  RCC->AHB1ENR = RCC_AHB1ENR_GPIODEN;
  //Bit 16 HSEON: HSE clock enable (1: HSE oscillator ON)
  RCC->CR |= RCC_CR_HSEON;
  //Bit 17 HSERDY: HSE clock ready flag (1: HSE oscillator ready)
  while((RCC->CR & RCC_CR_HSERDY)==0);
  //GPIO port mode register (all PORTD = 01: General purpose output mode)
  GPIOD->MODER   = GPIO_MODER_MODER12_0 | GPIO_MODER_MODER13_0 | GPIO_MODER_MODER14_0 | GPIO_MODER_MODER15_0;
  //GPIO port speed reg. (all portd = 10: 50 MHz Fast speed)
  GPIOD->OSPEEDR = GPIO_OSPEEDER_OSPEEDR12_1 | GPIO_OSPEEDER_OSPEEDR13_1 | GPIO_OSPEEDER_OSPEEDR14_1 | GPIO_OSPEEDER_OSPEEDR15_1;
  while(1)
    //My Crap Delay (~500,000 clks)
    delay(50000);
    //GPIO port output data register (ALL HIGH)
    GPIOD->ODR = LED1 | LED2 | LED3 | LED4;
    delay(50000);
    //GPIO port output data register (ALL LOW)
    GPIOD->ODR &= ~(LED1 | LED2 | LED3 | LED4);
  while(ticks--);
side note mouser sells MCU only for $17 and EVAL for $16.35.... wow crazy... I will def get the board. But wont be in stock til 1/9/2012
Jason That code looks sweet thankes for posting it
Im working on getting the PLL stuff right so i can use this bad boy at full speed: 168MHz (1.25DMIP/mhz) = 210DMIP
There are so many setting for the clocks its crazy! I have PLL with correct values now i need RCC CFGR and RCC RC registers.
This is driving me crazy! I know the PLL and stuff is getting set but nothing seems to be working. Im trying this code for now. Im trying to debug and it keeps crashing!
void initDiscovery(void)
  RCC->CR &= 0xf0f0ff04;   //Clear Register without changing reserved bits or Calibration
  RCC->PLLCFGR &= 0xf0bc0000; //Clear Register without changing reserved bits
  RCC->PLLCFGR |= 0x7402a04;  // PLLQ:7, PLLSRC:HSE, PLLP:2, PLLN:168,PLLM:4
  RCC->CFGR &= 0x300;       //Clear Register without changing reserved bits
  RCC->CFGR |= 0xc0689402;  //MCO2:PLL, MCO1:PLL, RTCPRE:8, PPRE2:2, PPRE1:4, SW:PLL
  RCC->CR |= 0x1010000;    //PLL ON, HSE ON
  while((RCC->CR & 0x2020000)==0);  //Wait for HSE and PLL to stabilize
  RCC->AHB1ENR &= 0x818bee00;  //Clear Register without changing reserved bits
  RCC->AHB1ENR |= 0x1ff;       //IO port A:I clock enable
  GPIOA->MODER = 0x55555555;    // ALL GPO (General Purpose Output)
  GPIOA->OSPEEDR = 0xaaaaaaaa;  //50Mhz Speed
  GPIOA->PUPDR = 0;             //NO PULL UP/DOWN
  GPIOB->MODER = 0x55555555;    // ALL GPO (General Purpose Output)
  GPIOB->OSPEEDR = 0xaaaaaaaa;  //50Mhz Speed
  GPIOB->PUPDR = 0;             //NO PULL UP/DOWN
  GPIOC->MODER = 0x55555555;    // ALL GPO (General Purpose Output)
  GPIOC->OSPEEDR = 0xaaaaaaaa;  //50Mhz Speed
  GPIOC->PUPDR = 0;             //NO PULL UP/DOWN
  GPIOD->MODER = 0x55555555;    // ALL GPO (General Purpose Output)
  GPIOD->OSPEEDR = 0xaaaaaaaa;  //50Mhz Speed
  GPIOD->PUPDR = 0;             //NO PULL UP/DOWN
  GPIOE->MODER = 0x55555555;    // ALL GPO (General Purpose Output)
  GPIOE->OSPEEDR = 0xaaaaaaaa;  //50Mhz Speed
  GPIOE->PUPDR = 0;             //NO PULL UP/DOWN
  GPIOF->MODER = 0x55555555;    // ALL GPO (General Purpose Output)
  GPIOF->OSPEEDR = 0xaaaaaaaa;  //50Mhz Speed
  GPIOF->PUPDR = 0;             //NO PULL UP/DOWN
  GPIOG->MODER = 0x55555555;    // ALL GPO (General Purpose Output)
  GPIOG->OSPEEDR = 0xaaaaaaaa;  //50Mhz Speed
  GPIOG->PUPDR = 0;             //NO PULL UP/DOWN
  GPIOH->MODER = 0x55555555;    // ALL GPO (General Purpose Output)
  GPIOH->OSPEEDR = 0xaaaaaaaa;  //50Mhz Speed
  GPIOH->PUPDR = 0;             //NO PULL UP/DOWN
  GPIOI->MODER = 0x55555555;    // ALL GPO (General Purpose Output)
  GPIOI->OSPEEDR = 0xaaaaaaaa;  //50Mhz Speed
  GPIOI->PUPDR = 0;             //NO PULL UP/DOWN
I would have to unplug then re-plug the USB cord just to get it recognized again in crossworks.. this sucks :(
The system_stm32f4xx.c file attached to this forum post was built using the Clock Config Tool Spreadsheet and is supposed to be for 168 MHz operation (with 48 MHz for USB)...
Thanks again here is a sample of what i got towards delays... Almost PERFECT!
speedtest-jpg.58295
wow im a idiot. Im trying to get a LCD to work assuming all the pins broken out are free and they are not so i made a EXCEL Sheet (image for you people) of all the PORT pins and which ones are used up and free... Used are highlighted.......
stm32f4usage-jpg.58331
