Timer1, CC5X & 16F631
Nayth
Hi
I'm trying to understand how to make the timer1 work
I have input on PORTA.4 and it pulses, and I want to check if there's more or less than 10 seconds between the pulses
TMR1CS = 0; //internal clock
TMR1ON = 1; //enables TIMER1
T1OSCEN = 0; //oscillator is shut-off
TMR1H = 0x00;
TMR1L = 0x00;
Then I thought I could do something like
if(Timer1 > 10)
 //Do Stuff
}else{
 //Do something else
I know the above code wont work and this is where I need your help, cause I just can't seem to find any info about how to set up Timer1 and then check how far it's counted.
Please write if I should supply more code
If I set
TMR1H = 0xFDE8;
Shouldn't it count to 65,000 and then roll over?
Another questen is, why is my program slowing down when I execute this command?
TMR1IF = 0;
That command should reset the interrupt flag for the timer, no?
I'm so lost with this Timer1, please help if you can
Thanks in advance
Same slowdown if I use
T1IF = 0;
I can't crack my head around why it slows down when I call that function
There's no slowdown when I reset the interrupt bit for Timer0
Anybody have an idea?
I also get an error saying that
Symbol 'TMR1' is undefined
Anybody know what that is, and what I can do about it?
