Timer
mrgobis
I am trying to write a simple program with Timer 0 using C 18 compiler. Please have a look at the following code and the following error code and let me know where i am going wrong.
#include <p18f4520.h>
#include <timers.h>
#define DELAY 16000
void mian (void)
TRISC = 0x00;
T0CON = 0b11000111;
while(1)
PORTC =0xFF;
TMR0 = 0;
while ( TMR0 < DELAY)
PORTC =0x00;
TMR0 = 0;
} // end
the following are the build errors
D:\PIC Projects\Loops2\LOOPS2.C:15:Error [1105] symbol 'TMR0' has not been defined
D:\PIC Projects\Loops2\LOOPS2.C:15:Error [1101] lvalue required
Please help me on this.
regards,
G.Nathan
#include <timers.h>
#define DELAY 16000
void mian (void)       <--------- Spelling Error -----------
TRISC = 0x00;
T0CON = 0b11000111;
while(1)
	PORTC =0xFF;
	TMR0 = 0;
	PORTC =0x00;
	TMR0 = 0;
} // end
regards,
G.Nathan
Do you have to OPEN and CONFIG the timer with OpenTimer0 ??
MPLAB C18 Lib manual pg 58.
I am looking at the timer stuff myself.
TIMER O with PIC C 18
Thanks for spotting the spelling error, i have read document on C18 Library. i am not sure how to open the timer and configure it. I have also tried many time. Please find the code below and please tell me where do i have to open the timer and configure.
#include <timers.h>
#define DELAY 160
void main (void)
TRISC = 0x00;
OpenTimer0( TIMER_INT_OFF & T0_8BIT & T0_SOURCE_INT & T0_PS_1_32 );
while(1)
PORTC =0xFF;
TMR = 0;
PORTC =0x00;
TMR0 = 0;
} // end code
following are the error message, It says TMR0 is not difined. Can some body tell me how to define the TMR0. I am sure i am making a school boy error here
D:\PIC Projects\Loops2\LOOPS2.C:13:Error [1105] symbol 'TMR' has not been defined
D:\PIC Projects\Loops2\LOOPS2.C:13:Error [1101] lvalue required
regards,
G.Nathan
The error states that TMR is not defined and I think you are reading it as TMR0. Change the line TMR=0 to TMR0=0 and all will be well. As you suspected, a schoolboy error and one I'm sure you won't repeat.
Good all! i've been trying to design a code in assembly for 16f84a for digital clock, pls is there any body that can help me out there am new in assembly.
