timer circuit needed
mart_1986
hi there
im after a circuit that will allow me to open blinds for 1minute or less at 10am and shut of at 6pm
You need a microcontroller and MIKEMI's motor reversing circuit with limit switches. Search his recent posts or look for the motor reversing threads. You might substitute the CD4060 for the microcontroller. Good luck!
Do you already have a motorized drive for the blinds?
If so, what voltage does it run on? You might as well incorporate the timer into the drive.
What is the 1 minute period? Is that how long the motor must run for the blinds to completely open or close?
Does the blind actuator have its own limit switches? i.e. does it stop moving when the blinds reach the fully open/full closed position?
i need it for my pigeon loft the blind make the shed dark (its complicated to explain)
im building it from scatch i need to make a normal hand open blind motorised i going to use a car electic window motor
iim building it from scatch i need to make a normal hand open blind motorised i going to use a car electic window motor
The mechanicals will be the hardest part , the timer is simple
