This is for my project
mramos1
Active Member
Jenith04 said:
can any one mail me a simple program to learn how to program and set a LCD display using PIC16F877
Not sure if there is anything like that on bastoc.com, the RVKBASIC forum or
the tutorials in the download. Oh shoot, you said PIC, I was thinking ATMEL.
Maybe Microlab Engineering BASIC compiler site will have sample code.
I am sure if you google you should fine plenty on samples.
atferrari
Assembler, Basic, or C? What LCD display?
What language do you use :?:
What LCD display? Graphic / text :?: How many lines :?:
Asking proper questions :idea: (enough details) is the minimum to get valid answers.
Help others to help you :!: :!:
Jenith04
Re: Assembler, Basic, or C? What LCD display?
using the assembly language, the program should display numbers from 1 to 50 also a sentance when pressed a particular switich. I've only the target board with an LCD as an output or you can also display the numbers on a 7 segment LED. Actually you need two seven segment LED's to display numbers from 1 to 50.
Jenith04
I also need to display my numbers on a dual 7 segment Led. the numbers should increment from 1 to 50 when a certain switch is pressed and should also decrease from the current value when another switch is pressed.
the program should be done using assembly in PIC16F877
I'll be very thankfull if you can get me some program like my one.
cheers
EE World Online Articles
Loading
