The TLC548 A/D connected to a timer
richacm
I have a TLC548 A/D convertor and I want to pulse it every 2 minutes to convert the voltage input to the digital output.
I've set up the circuit for the timer (using a TLC555 timer) and I'm not too sure where I place the output from the timer. Do I connect it to the I/O clock or do I just need to connect it to the CS and forget about the clock?
Thanks,
Craig
It's a bit vague what you're trying to do?, can you post a circuit of what you have so far?.
But by the sound of things a PIC would make your project a LOT easier - just a single chip.
Thanks,
Craig
As stated already, the details you have given are vague.
The 555 clock goes to the I/O clk of the TLC548, which then clocks out the Data.
It requires /CS pulse to initiate a conversion.
How are you going to read the Data out.?
Hi, thanks for the replies. Attached is my circuit to date.
I have a pressure sensor that will take a reading and then update LED displays indicating how full a tank is. At the same time I want to take a sample of the pressure every 2 minutes. This is what the Clock and the ADC are for. The clock will fire the ADC every 2 minutes and a sample is taken. The result is to be stored in to a FIFO store which I will then connect to and get the data (a further project!).
Cheers,
Craig
Cheers,
Craig
The /CS pin on the A2D is 'floating' on the circuit diagram, it must be controlled to initiate a conversion cycle.
OK, so after 2 minutes the clock pulses and has a high setting for 1 second. I attach this to the /CS pin to initiate the conversation.
Since the TLC548 has its own internal clock won't 8 bits of data just appear on the output - I don't need any more. Or do I need to wire to the I/O clk and cycle 8 times to get a high/low value? If this is the case can you point me to any circuits that do this...i.e. delay for X seconds and the clk Y times for Y bits of data.
Thanks for the help,
Craig
Craig
Hi Craig,
Look at the attached extract from the datasheet.:)
The data is clocked out by the external clock on the I/O pin
Note the required use of the /CS pin and the initiate I/O clock cycles.
Aha, thanks. This is going to be tricky then :)
I did see a circuit some time ago, which I cant relocate.:confused:
It used a 555 for the I/O clk and a 4017 ic to generate a /CS pulse every ninth clock pulse.
Why dont you look thru the PIC options.?
Wow, just ordered my PIC programmer. I forgot about these components - aren't they cool. No need for my TLC548 ADC any more either. I think I am going to do away with everything except the Pressure sensor and the op-amp. I'll replace everything else with a couple of PIC components.
Is this the forum for reviewing PIC code at all?
