futz
Active Member
Hot water recirc is actually very simple. No extra tank needed. Just some circ lines that go typically one to each area with plumbing, a simple manifold with balancing valves and a relatively cheap circulator (pump) with timer and aquastat. Whenever the timer says it can run, and the aquastat says it's cold, the pump pulls water from the far ends of the system and pushes it back in the cold side of the water tank, forcing hot water out into the hot mains. That way it's close to the faucets and ready for quick use. This setup can't be easily retrofit in most houses without a major renovation though.crashsite said:I also believe there are methods for "purging" the hot water from the pipe and returning it to the master tank so the heat is not lost between hot water uses. But, it's a rather nasty, complex system that might be more trouble than it's worth (involves an extra tank and electric pumps).
There are systems like Grundfos' UP15-10 Comfort System that allow you to retrofit hot water recirc to an existing home. Quite a smart design. Uses the cold line as a return, so no need for new return lines. There are other brands too, but Grundfos is top quality stuff.
Anyway, we're getting pretty darn off-topic here...
