The command ORG
I cant understand the function of ORG exactly...
Thank you
ORG is short for Origin.
Its what the Assembler uses as the start of the Program Counter in the program.
Example:
ORG 0x0000 ; would tell the assembler to start the Program Counter at 0000
ORG 0x0004 ; would tell the assembler to start the Program Counter at 0004
Do you follow. OK.?:)
I thought ORG moves the following code up to the memory address given.
Expanding upon what I said, just for clarity, I mean that if you go
ORG 0x0004
(something)
ORG 0x0008
(something)
It'd end up compiling into NOP's until 0x0004, the instruction, then NOP's until 0x0008.
ORG 0x0004
(something)
ORG 0x0008
(something)
hi AG,
It wouldnt fill the gaps in ORG 0x0004 to ORG 0x0008 with NOP's if the 'something' in your example was a program/assembler instruction.
No, it won't create any code for those addresses - unless it's been told to.
Isn't that what I said.:confused::p
The program memory will be 3fff for the unused locations.
