Tall SMD tact switch required please. - Any leads?
Hello All.
I've asked about this before (about 5 or 6 months ago, but the thread got sent off track). - I'm asking again in case any of you have seen what I'm looking for:
I am looking for an SMD tact switch with a long actuator, ideally around 20mm. (I am aware that PCB, rather than SMD, versions exist).
I've had no luck so far, beyond finding a 9.5mm high switch on Farnell UK. (- I've just contacted them to inquire whether they do the next highest in the series which is 13mm.)
Do any of you know where I could find such a thing, please?
Thanks in advance.
Analogue.
Hi Analogue,
A few years ago I needed some tactiles that were 35mm high at least and could only get 20mm then.
I simply made a few adaptors, its really easy. Just get some plastic the same diameter as the tactiles button size and add to the length of the originals. Then you could get a sleeve of plastic that fits around them and glue it in place, or do like I did and just shrink fit them together! I found that 2 layers of shrink fit made the whole joint very solid.
Hope this helps.
Al
220C150QBLK from E-Switch
1241.1624.71 from Schurter Inc
and see attached.
All a little short but close
@ All who have responded: Thanks for your suggestions. - This is the kind of thing I'm looking for, but in an SMD version: 20mm(+) high, footprint ideally about 6x6mm (need a relatively small footprint to keep size of circuit-board reasonable):
https://www.altronics.com.au/index.asp?area=item&id=S1119
- I contacted their company a while ago: They could get the SMD version, but their minimum order was about 10,000 pieces (no, I'm not exaggerating: literally). - Far more than I require and obviously not economical for me. Pity, since the price per unit seems ok.
@ KJ6EAD: Thanks for the link. - Yes, many manufacturers have c.15mm, but 20mm (and beyond) seems almost impossible to find.
@ Bigal_Scorpio: Very good solution, Bigal - thanks. But right now I'm looking for an "off-the-shelf" switch. - Are you able to recall who had the 20mm version you mentioned, please?
@ ronsimpson: Thanks for the suggestions, ron. - Certainly getting close to what I'm looking for regarding height.
Analogue.
