Optikon
OK, so where is an ideal switch!? I found a part called "sw" as voltage controlled switch but you gotta put a subcircuit behind it... guhh...
Did I miss it somewhere? I need an ideal switch to simulate a mechanical relay.. surely someone has used an ideal switch in this simulator.. can you point me to where you found it or a link for a good subckt? Or even post the model you use if I have to add a subckt.
Thanks!
Thanks!
