I'm building an art clock. I want to have an electric motor drive some steampunk-type gears that will eventually turn an hour hand (no minute/second hands). The gears will mostly be scrounged from some old clocks and will chosen for their coolness factor so the motor speed will have to be adjusted accordingly. Currently I'm planning a motor speed of 600-1000 RPM but I'm flexible.
I can go to Digikey or similar and buy a motor but I'm not sure what would best suit my needs. I'd like a motor that was:
1) Easily adjustable so that I can make the clock relatively accurate. I can probably handle adding a motor driver if necessary.
2) Rock-steady RPM and reliable. I plan on running it 24/7.
3) Low voltage. The clock will be hanging on the wall so I want as thin a cord/wire as possible. Something like 30 gauge magnet wire (paired) would be ideal but I can use other wire if necessary.
4) Quiet.
Do you guys have suggestions on what/where I should look? Since it will be geared down so low I assume that I don't need much torque; just enough to overcome the friction of the gears. Is there anything else I should be considering?
Thanks!
4) Quiet.
Thanks!
