roundrightfarm
I recently bought a used box truck. As I was getting ready to make the purchase, the dealer said they were having trouble with a blown hazard light fuse. They found a non-OEM flasher unit for LED lights installed and so they replaced it with the OEM flasher. This made it work temporarily, but soon the fuse was blown again. I replaced the fuse, but now the flasher is acting funny. All 4 turn signal bulbs (which are controlled by the same flasher as the hazards) are functioning, but they are flashing faster than normal, as if one of the bulbs was burned out. Now when I turn on the hazard switch, they do not light up and the flasher unit (relay type) is rapidly clicking. The 20amp fuse is holding.
I am a little reluctant to replace the flasher without figuring out what happened. The flasher is expensive and if the recently installed one went bad as a result of something else wrong in the system, I'd like to not replace it for the third time.
Does anyone have an idea what this behavior could signify?
