Thanks... it was nothing... now when i get a LCD working on this ill be happy heh... havent touched it ever since tho![]()
I'm using the Cosmic compiler, but not sure how to download the code into the training kit yet. Anyway, these are nice stuff to play with.
I'll be ordering a 2nd training kit with some cheapo Microchip temperature sensors, and if I have the time, I'll be making a cheap radio-clock!
However the DIP versions are not out yet - apparently these STM8S are very new. I hope Farnell or RS will stock up on those stuff.
I use Cosmic as well... I followed the link in the above post.. that was very usefull.. I jumped in without knowing anything about the MCU at all. I still know nothing of it..
Farnell i know of ... whats RS ?
#include "stm8s.h"
#define LCD_PORT GPIOB
#define LCD_RS GPIO_PIN_0
#define LCD_E GPIO_PIN_1
void DelayMS(int delay);
void initLCD(void);
void LCD_DATA(unsigned char data,unsigned char type);
void LCD_NYB(unsigned char nyb, char type);
void LCD_LINE(char line);
void LCD_STR(const unsigned char *text);
int main(void) {
GPIO_DeInit(LCD_PORT);
GPIO_Init(LCD_PORT, GPIO_PIN_ALL, GPIO_MODE_OUT_PP_LOW_FAST);
initLCD();
LCD_LINE(1);
LCD_STR(" AtomSoftTech ");
DelayMS(100);
LCD_LINE(2);
LCD_STR(" Jason Lopez ");
DelayMS(100);
while(1);
void LCD_STR(const unsigned char *text){
while(*text){
LCD_DATA(*text++,1);
void initLCD(void){
GPIO_WriteLow(LCD_PORT,LCD_E); //clear enable
GPIO_WriteLow(LCD_PORT,LCD_RS); //going to write command
DelayMS(30); //delay for LCD to initialise.
LCD_NYB(0x03,0); //Required for initialisation
DelayMS(5); //required delay
DelayMS(1); //required delay
LCD_DATA(0x02,0); //set to 4 bit interface, 1 line and 5*7 font
LCD_DATA(0x28,0); //set to 4 bit interface, 2 line and 5*10 font
LCD_DATA(0x0c,0); //set to 4 bit interface, 2 line and 5*7 font
LCD_DATA(0x01,0); //clear display
LCD_DATA(0x06,0); //move cursor right after write
void LCD_DATA(unsigned char data,unsigned char type){
DelayMS(10); //TEST LCD FOR BUSY
LCD_NYB(data>>4,type); //WRITE THE UPPER NIBBLE
LCD_NYB(data,type); //WRITE THE LOWER NIBBLE
void LCD_NYB(unsigned char nyb, char type){
unsigned char temp;
temp = (nyb<<4) & 0xF0;
GPIO_Write(LCD_PORT,temp);
if(type == 0){
GPIO_WriteLow(LCD_PORT,LCD_RS); //COMMAND MODE
} else {
GPIO_WriteHigh(LCD_PORT,LCD_RS); //CHARACTER/DATA MODE
GPIO_WriteHigh(LCD_PORT,LCD_E); //ENABLE LCD DATA LINE
DelayMS(1); //SMALL DELAY
GPIO_WriteLow(LCD_PORT,LCD_E); //DISABLE LCD DATA LINE
void LCD_LINE(char line){
switch(line){
case 0:
case 1:
LCD_DATA(0x80,0);
break;
case 2:
LCD_DATA(0xC0,0);
break;
void DelayMS(int delay){
int nCount = 0;
while (delay != 0){
nCount = 100;
while (nCount != 0){
nCount--;
delay--;
#include "stm8s.h"
#include "lcd.h"
int main(void) {
initLCD();
LCD_LINE(1);
DelayMS(100);
LCD_LINE(2);
DelayMS(100);
while(1);
the compiler itself doesnt come with anything but the main ST program has a ton of examples... i mean you will get lost in it...
There are a ton heh... there is more down the list. with lots of info in there:
I also love to buy one. But the shipping cost is 5 times more that the product.At Gigikey
switch(line){
case 1:
LCD_DATA(0x80,0);
break;
case 2:
LCD_DATA(0xC0,0);
break;
case 3:
LCD_DATA(0x94,0);
break;
case 4:
LCD_DATA(0xD4,0);
break;
