Steps in Learning - RTOS (REAL TIME OPERATING SYSTEM)
Dear all,
I want to learn RTOS.
For this - I've selected 'microcontroller as 8051' and 'Free RTOS'.
What's the next step ? where to go..?
Please Guide...
I like the 8051.. very much, but support is dying, so factor that in before you start..
The basic 8051 isn't very resourcefull so you'll need to add peripherals... There is a port of freeRtos for the 8051 here https://www.freertos.org/portcygn.html but you'll really need to use their compiler.. I think there is a free version. You can use SDCC ( free compiler ) there is information on that web site. https://www.freertos.org/FreeRTOS_S...Compiling_Cygnal_demo_using_SDCC_1444640.html
You need to compile the RTOS for the compiler you need to use.. Good luck.. Quite advanced stuff. May I ask what its intended use is.
...You need to compile the RTOS for the compiler you need to use.. Good luck.. Quite advanced stuff. May I ask what its intended use is.
Dear sir,
All i require is - 'to learn RTOS and how to use it'...
Microcontroller like 8051 is not an issue... I may change the microcontroller if required...
The matter is 'how to use RTOS' and what are its applications ...
Regards,
Simran
I need to brush up my skills...:)
Learning an RTOS isn't your first step.... The microcontroller 8051 is easy to learn on ( hence why its used in schools ) Build a circuit and down load the RTOS and compile it.. once you can get task 1 to blink an LED at 4 hz and task 2 to blink one at 2hz you are there.. RTOS can be simple tasks..
