Start-Stop & emergency stop
Shohadawy
In electrical control panels you may see a Stop pushbutton and an emergency stop pushbutton on the same panel, What is the difference between them?
The stop-function is for normal operation, e.g. stopping a drive by mechanically disengaging it. The emergency-stop generally deenergizes the entire machine.
Boncuk
In our industry applications E-Stops are used to remove the control voltage to the control circuit. This prevents anyone from issuing a start command either remotely (control room), locally (at the MCC (Motor control centre)) or in the field.
The E-Stop switch is usually also a mechanical latching type switch, that requires you to turn the knob before it will release. Additional safety feature.
The Stop pushbutton is wired in series with the control relay (a N/C switch) and once the stop pb is pressed, power will be removed to the relay, the contacts open up and power is removed from the drive.
