rmain1972
Hello all,
I'm working on interfacing a 2 Digit CC display to a MC14489B using SPI and a 16F818 chip. The chip hangs in a loop because a test LED never blinks, but stays on steady. When the communication with the MC14489B is commented out, ie init and display routine, the test LED blinks.
I have verified wire connections using a multi-meter checking for continuity. All the pins check out. As below
16F818 MC14489B
7 SDI -- DATA OUT -- 18
8 SDO -- DATA IN -- 12
10 SCK -- CLOCK -- 11
11 RB5 -- ENABLE -- 10
I suspect that it may be code that is the issue. I took the code from a power point available on the microchip site. Below is the code that I am using. Understand that I'm only trying to initialize the chip first with one byte of data, then I will send the 3 display bytes.
Any help or ideas would be helpful. What sucks is that I had it working in the past (2006) with a frequency counter on a different breadboard, but a crashed hard drive and no backup prevents me from looking at what I did in the past.
Thanks.
16F818 MC14489B
Thanks.
list p=16f818 ; list directive to define processor
#include <p16F818.inc> ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
__CONFIG _CP_OFF & _WRT_ENABLE_OFF & _CPD_OFF & _CCP1_RB2 & _DEBUG_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_IO
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See data sheet for additional information on configuration word settings.
;***** VARIABLE DEFINITIONS
w_temp EQU 0x7E ; variable used for context saving
status_temp EQU 0x7F ; variable used for context saving
cblock 0x20 ; general purpose ram starts as 0x20 on the 16F818
d1
d2
d3
outbyte1
outbyte2
outbyte3
endc
ORG 0x000 ; processor reset vector
goto main ; go to beginning of program
ORG 0x004 ; interrupt vector location
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
main
; remaining code goes here
; set internal clock speed
banksel OSCCON
movlw b'01110000' ;8MHz internal RC oscilator
; x111xxxx
movwf OSCCON ;set the new clock speed
nop
nop
nop
nop
;Setup SPI Mode
banksel SSPCON ; SPI Configuration
movlw b'0010000' ; bit 7 Write Collision Detect bit - 0
movwf SSPCON ; bit 6 Recieve Overflow bit - 0
; bit 5 Synchronous Serial Port Enable - 1 Turn On SPI Mode, Enable and configure SCK, SDO, and SDI
; bit 4 Clock Polarity bit - 0 TX on rising edge, RX on falling edge, IDLE state for clock is a low level
; bit 3-0 Synchronous Serial Port Mode Select - 0000 SPI Master Mode, clock OSC/4
; Must also configure TRISB bits as appropriate for SCK, SDO, and SDI
; Setup Port B
banksel TRISB ; TRISB is in Bank 1
movlw b'11001010' ; Intended Function
movwf TRISB ; bit 7 (RB7) Available - 1 (Default Input)
; bit 6 (RB6) Available - 1 (Default Input)
; bit 5 (RB5) Used to Enable MC14489B Display Driver - 0 (Output)
; bit 4 (RB4) Overriden by SSP Module as SCK - 0 (Output)
; bit 3 (RB3) Available - 1 (Default Input)
; bit 2 (RB2) Overriden by SSP Module as SDO - 0 (Output)
; bit 1 (RB1) Overriden by SSP Module as SDI - 1 (Input)
; bit 0 (RB0) to output so we can source a LED to indicate on condition - 0 (Output)
; OPTION Register is in Bank 1
;bsf OPTION, 7 ; Disable PORTB weak pull ups
; Initilize MC14489B Display Driver
call InitMC14489B
; Test MC14489B
; Display 1, 2, 3 on 3 Digit Display
; Digit 2 Digit 1
; movlw b'00100001' ; 0010 = 2, 0001 = 1
; movwf outbyte1
; Digit 4 Digit 3
; movlw b'00000011' ; 0000 = 0, 0011 = 3
; movwf outbyte2
; D23 = High, Brighten LEDs
; D22-D20 = Low, Activate h in all banks
; movlw b'10000000' ; Digit 5 = 0000
; movwf outbyte3
; call SendDisplayInfo ; Transmit 3 bytes of data to MC14489B
banksel PORTB ; Bank 0
Loop
bcf PORTB, 0 ; Turn off LED
call Delay ; Delay 1 second
bsf PORTB, 0 ; Turn on LED
goto Loop
; Delay Code
; Delay = 1 seconds
; Clock frequency = 8 MHz
; Actual delay = 1 seconds = 2000000 cycles
; Error = 0 %
Delay
;1999996 cycles
movlw 0x11
movwf d1
movlw 0x5D
movwf d2
movlw 0x05
movwf d3
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto $+2
decfsz d3, f
goto Delay_0
;4 cycles (including call)
return
; Init MC14489B Display Driver
InitMC14489B
banksel PORTB
bsf PORTB, 5 ; Initilize ENABLE to High
movlw b'00000001' ; C7 = L, No Decode
; C6 = L, No Decode
; C5 = L, Hex Decode Digit 5
; C4 = L, Hex Decode Digit 4
; C3 = L, Hex Decode Digit 3
; C2 = L, Hex Decode Digit 2
; C1 = L, Hex Decode Digit 1
; C0 = H, Normal Mode
movwf outbyte1
call SendByte ; Send the configuration byte to the MC14489B
return
SendByte
banksel PORTB ; PORTB and SSPBUF are in the same bank
bcf PORTB, 5 ; Set ENABLE to LOW to signal that we are sending data
movf outbyte1, w
movwf SSPBUF ; Transmit byte
banksel SSPSTAT
SBWait1
btfss SSPSTAT, BF ; Data transfer complete?
goto SBWait1
banksel PORTB
bsf PORTB, 5 ; Set Enable to HIGH to signal that we are done sending data
return
SendDisplayInfo
movf outbyte1, w
movwf SSPBUF ; Send Byte 1
banksel SSPSTAT ; Data transfer complete?
SDWait1
btfss SSPSTAT, BF
goto SDWait1
banksel outbyte2
movf outbyte2, w
movwf SSPBUF ; Send Byte 2
banksel SSPSTAT
SDWait2
btfss SSPSTAT, BF
goto SDWait2
banksel outbyte3
movf outbyte3, w
movwf SSPBUF ; Send Byte 3
banksel SSPSTAT
SDWait3
btfss SSPSTAT, BF
goto SDWait3
bsf PORTB, 5 ; Set ENABLE to HIGH to singal that we are done sending data
return
