Sonsiviri PIC Basic Plus error
Beefer3
Can someone tell me why this does not work when compiling with PIC Basic Plus from sonsiviri.com
IF [STR SERDATA] = "HouseLights1" THEN
CLS
PRINT AT 1,1, "Turning on"
PRINT AT 2,1, "the house."
ENDIF
I get this error:
Error at Line [45] In file [SonyCD.bas] *** Misplaced or Incorrect 'ENDIF' command! ***
all my other IF THEN statements work in my code. I have a feeling it is the [STR SERDATA] bit. How do I fix this or is this just a PIC Basic Plus program error?
thanks
Get rid of the "THEN"
Using "Endif" indicates that you are excuting more then one command after the "If" statement.
Ex.
IF A>B THEN
Do One thing...
IF A>B
Do First thing
Do Second thing
ENDIF
Well that how basic language is, I'm not sure if the compiler you are using follow this rule.
thanks CoTang. I will give it a try
Are you sure you can compare strings? PICBasic Pro CAN'T :evil: so I just wonder if yours can.
Ivancho
CoTang
Thanks but getting rid of the 'THEN' did not work.
Does anyone know how to compare strings?
Maybe convert the IF THEN statement into assembly?
This has been a thorn in my side for my project.
If anyone has any suggestions let me know.
