We have a machine that was bought many months back. It ran but they were having some issues with the spindle VFD shutting down. DUH!!!! The machine was obviously close to cast iron dust and these guys did NOT take care of it the air filtration and there is likely conductive dust all over the interior PCBs.
We discussed removing boards, cleaning, etc, etc, but it will take a serious amount of time and most certainly some risk in that. What we discussed is simply using an automotive spray gun loaded with a "recommended solvent" that will be safe for everything. I suspect safe will not make things perfectly clean again but we also don't want to go rinsing off solder masks or otherwise damaging boards. I just don't think air by itself will be effective and manually cleaning just won't work.
I was thinking isopropyl but that stuff seems to rarely work around here for cleaning boards. I know there will be oil deposit, not just dust. I am hoping to feather between solvent spray to just straight air, then hoping the solvent will help break stuff down and we can finish with fine air to get the crud out.
the other mode of attack is to use a large and soft paint brush, dip in alcohol or other solvent, wash down the PCB, then finish with air. In all cases, there are just places that are almost impossible to access so either mass brushing or air will have to be it. I do have concerns getting stuff up under chips but I think we decided the potential pros out weight the cons as the machine already has reliability issues due to contamination and more shorting may zap the machine anyway.
Speaking of zap, I might ask for ways to minimize spark concerns. I know compressed air release can and does build a charge. I need to make certain we cover this base. My best friend has been a pro auto painter for decades and never had an issue and they are shooting stuff 10x more volatile than alcohol but...... they are shooting stuff wet and I want a fine mist of solvent with mostly air.
