software PWM
Never knew that // was a comment in basic, thought it was a C thing. In basics I've used it's normally '
Swordfish will accept either style as a comment.
Block comments are a bit different though. There is uses "(*" and "*)" for begin-end comment block.
I think I have hit a very simple loop that changes the led brightness or dimness.
In order to dim you must turn off the led thus the delays. In this simple loop, the delay is varied in accordance with the INDEX
I am using DEKAYMS(XXX) so I can see the rate of flash increase then decrease etc.
post #2 & 5 got me to rethink how to do this simple task which incorporates most all suggestions
Am using INDEX as a LONGWORD to length the transition time between bright and dim.
The flash rate increases then decreases which indicates it is maybe doing as desired. Will try using DELAYUS instead of DELAYMS.
*  Name    : UNTITLED.BAS                                                   *
*  Author  : [select VIEW...EDITOR OPTIONS]                                 *
*  Notice  : Copyright (c) 2022 [select VIEW...EDITOR OPTIONS]              *
*          : All Rights Reserved                                            *
*  Date    : 5/21/2022                                                      *
*  Version : 1.0                                                            *
*  Notes   :  copy n pasted from
Report
rjenkinsgb                                                              *
Device = 18F43K22
Clock = 8
// int osc and IO pin libraries
Include "intosc.bas"
#option DIGITALIO_INIT = true       // automatically call setalldigital
Include "setdigitalio.bas"
Include "convert.bas"
//LEDS
DIM LED1 AS PORTA.0
DIM LED2 AS PORTB.0
DIM LED3 AS PORTC.0
DIM LED4 AS PORTD.0
DIM Time1 AS BYTE
DIM Time2 AS BYTE
DIM Time3 AS BYTE
DIM Time4 AS BYTE
DIM INDEX AS LONGWORD
dim counter as LONGWORD
dim Bright as longword        // a wider range of settings
dim Dimmer as longword
//LEDS ALL OFF AT START OF PROGRAM
led1 = 0
led2 = 0
led3 = 0
led4 = 0
Time1 = 25
Time2 = 50
Time3 = 75
Time4 = 100
//INCREMENT/ DECRIMINATE ON/OFF TIMES
INDEX = 1
//MAKE ALL OUTPUTS
trisa=0
'trisb=0
'trisc=0
'trisd=0
While TRUE
   // LED One control
   IF INDEX <=10000 THEN
   TIME1 = (TIME1 + INDEX)
   endif
       led1=1
       delayMs(Time1)             //INCREMENT THIS FOR BRIGHTER
       led1=0
       DELAYMS(TIME1)
      // LED One control
   IF INDEX >=10000 THEN
   TIME1 = (TIME1 - INDEX)
   endif
       led1=1
       delayMs(Time1)             // DECRIMENT FOR DIMMER
       led1=0
       DELAYMS(TIME1)
  INDEX = (INDEX +1)    //INCRIMENT INDEX EACH PASS THROUGH LOOP
      IF INDEX >= 10000 THEN
      INDEX = (INDEX - 1)
   End If
Wend
Nevermind. Suggestions won't be taken anyway.
now this starts out really dim then goes bright really smooth but it won't go from full bright back to dim
BRIGHT_1 = 1
DIMMER_1 = 25000
BRIGHT_2 = 25000
DIMMER_2 = 1
INDEX = 1
//MAKE ALL OUTPUTS
trisa=0
'trisb=0
'trisc=0
'trisd=0
While TRUE
//this is a real smooth from dim to bright
repeat
  led1 = 1
  delayus(bright_1)  // 1
  led1 = 0                   // dim
  delayus (dimmer_1)  //25000
  bright_1 = (bright_1 +1)
  dimmer_1 = (dimmer_1 - 1)
 until
 bright_1 = 2500
//this won't go back to dim??
 repeat
  led1 = 1
  delayus(dimmer_2)  // 1
  led1 = 0                   // full bright
  delayus (bright_2)  //255
  bright_2 = (bright_2 -1)
  dimmer_2 = (dimmer_2 + 1)
 until
 dimmer_2 = 2500
wend
Since you won't try suggestions that will work, and keep heading down paths that won't work, it's doubtful that anybody will attempt to decipher your code.
What I did was started from scratch to find out what ratio of LED ON TIME vers OFF TIME
try this and you will see what I am talking about
for a full dim
LED = 1 Delayus(1)
LED = 0 Delayus(25000)
this will dim the LED almost off
Now reverse the combination
LED=1 Delayus(25000)
led=0 Delayus(1)
While watching tv last night I was pondering my code and realized I need to reset the values of bright_1 and bright_2
bright _2 = bright_1 insert before second UNTIL LOOP
dimmer_2 = dimmer_1 insert AFTER THE SECOND until loop
after I finish this post will give it a go
Post 2 & 5 started my rethinking process about how to do a software only PWM simulation so thanks
THIS CODE WORKS PERFECT as desired
A really s m o o t h transition from very dim to very bright. Found a glitch AFTER I added a transition indicator led2
Just that small addition helped locate the issue of a jump from full bright back to full dim
*  Version : 1.0                                                            *
*  Notes   :  WORKS GREAT 5/23/22                                                             *
Device = 18F43K22
Clock = 8
//LEDS
DIM LED1 AS PORTA.0
DIM LED2 AS PORTE.1
DIM LED3 AS PORTC.0
DIM LED4 AS PORTD.0
dim Bright_1 as longword        // a wider range of settings FOR A SMOOTHER TRANSITION
dim Dimmer_1 as longword
dim Bright_2 as longword        // a wider range of settings
dim Dimmer_2 as longword
led1 = 0
led2 = 0
led3 = 0
led4 = 0
BRIGHT_1 = 0
DIMMER_1 = 0
BRIGHT_2 = 0
DIMMER_2 = 0
INDEX = 1
//MAKE ALL OUTPUTS
'trisa=0
'trisb=0
'trisc=0
'trisd=0
OUTPUT (LED1)
OUTPUT(LED2)
//     USING VALUE OF 5000 FOR A S M O O T H TRANSITION.
While TRUE
 bright_1 = 1              // bright_1 is ON  time variable
 dimmer_1 = 5000           //dimmer_1 is OFF time variable
repeat
  led1 = 1
  delayus(bright_1)
  led1 = 0                   // dim
  delayus (dimmer_1)
  bright_1 = (bright_1 +1)   // increase ON time BY 1
  dimmer_1 = (dimmer_1 - 1)  //decrease OFF time BY 1
 until
 bright_1 >= 5000            //HIGH BRIGHT
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
//reset values
  bright_2 = 5000
  dimmer_2 = 1
  LED2 = 1                    // LED2 COMES ON WHEN LED1 STARTS FROM HIGH BRIGHT TO FULL DIM
 repeat
  led1 = 1
  delayus(BRIGHT_2)           // LED is full brightness  FIRST PASS IN LOOP
  led1 = 0
  delayus(DIMMER_2)           // full dim          FIRST PASS IN LOOP
  bright_2 = (bright_2 - 1)
 until
 bright_2 = 1
//reset valuesxxxxxxxxxxxxxx
  bright_2 = 1
  dimmer_2 = 5000
  LED2 = 0                      // LED2 GOES OFF WHEN LED1 STARTS FROM FULL DIM  TO HIGH BRIGHT
wend
//increase brghtness
   REPEAT
   // LED One control
   IF INDEX <=255 THEN
   BRIGHT = (INDEX + 1)
   endif
       led1=1
       delayMs(DIMMER)             //INCREMENT THIS FOR BRIGHTER
       led1=0
       DELAYMS(BRIGHT)
   BRIGHT = (BRIGHT + 1)
   UNTIL
   BRIGHT >= INDEX
 // decrease brightness
 REPEAT
      // LED One control
   IF INDEX >= 1 THEN
   DIMMER = (INDEX)
   endif
       led1=1
       delayMs(BRIGHT)             // DECRIMENT FOR DIMMER
       led1=0
       DELAYMS(DIMMER)
    UNTIL
    DIMMER <= INDEX
      IF INDEX <= 255 THEN
      BRIGHT = (INDEX + 1)        // increase BRIGHT  until it hits 100000
      End If
       IF DIMMER >= 100000 THEN   //decrease  DIMMER  until it hits 0
      DIMMER = (INDEX - 1)
      End If
   ' if INDEX = 0 then index = (INDEX + 1) end if
    'if index = 1000000 then
Wend
Awesome.
But the problem is, as you have discovered already in this thread, comes when you try to do this with more LEDs.
that's my next challenge BUT I do have a really good fading in & out snippet that works.
got to start small then go big.
lets add more LEDs easy
Sub Fade()
 Bright_1 = 1              // bright_1 is ON  time variable
 Dimmer_1 = 5000           //dimmer_1 is OFF time variable
Repeat
  PORTA = %11100111
  DelayUS(Bright_1)
  PORTA = %00000000                   // dim
  DelayUS (Dimmer_1)
  Bright_1 = (Bright_1 +1)   // increase ON time BY 1
  Dimmer_1 = (Dimmer_1 - 1)  //decrease OFF time BY 1
 Until
 Bright_1 >= 5000            //HIGH BRIGHT
//reset values
  Bright_2 = 5000
  Dimmer_2 = 1
 ' LED2 = 1                    // LED2 COMES ON WHEN LED1 STARTS FROM HIGH BRIGHT TO FULL DIM
 Repeat
  PORTA = %11100111
  DelayUS(Bright_2)           // LED is full brightness  FIRST PASS IN LOOP
  PORTA =%00000000
  DelayUS(Dimmer_2)           // full dim          FIRST PASS IN LOOP
  Bright_2 = (Bright_2 - 1)
  Dimmer_2 = (Dimmer_2 + 1)
 Until
 Bright_2 = 1
  Bright_2 = 1
  Dimmer_2 = 5000
 ' LED2 = 0                      // LED2 GOES OFF WHEN LED1 STARTS FROM FULL DIM  TO HIGH BRIGHT
The issue is current draw. I have 14 pairs of white LEDs in parallel with one 330 ohm resistor per pair which should be around 7ma per pair. Same for the 20 pairs of blue
7 x 14 = 98 rounded off to 100 ma.
the pic data sheet says 180ma max so the BLUE and WHITE can't be on at the same time
14 pairs of white and 20 pairs of blue = a total of 68 leds.
IF I decide to have more boards made then a different pattern for the resistor arrays and use 750 ohm resistors
a definite design flaw
One way around it is TOGGLE THE BLUE?
Since MrDEB has been silent today, he may have figured out that a whole bunch of serial routines with delay statements aren't going to accomplish what he wants at least not very well.
One way to do what he wants is to base all actions on a loop counter, with at most exactly ONE delay statement. Ok, let's start with the basic program loop.
Dim Counter as Longword
Counter = 0
While 1 = 1
   // some code will go here
    Inc (Counter)
    If Counter > 4000000000 then
          Counter = 0
    End If
Wend
What happens in this program loop? The variable Counter counts from 0 to 4,000,000,000. This number can actually be 2^32, but rounding it off won't matter much. The IF statement may not be strictly necessary. The Counter value should automatically wrap back to zero.
Pretty neat, huh? Well, let's work on that. Let's add an LED, say at 50% brightness .
Dim LED1On as Longword
Dim LED1Off as Longword
LED1On  = 0
LED1Off = 0
Counter = 0
While 1 = 1
   If Counter = LED1On then
        LED1 = 1
        LED1On = Counter + 20
        LED1Off = Counter + 10
   End If
   If Counter = LED1Off then
       LED1 = 0
   End If
    Inc (Counter)
          Counter = 0
    End If
Wend
Ok, so what happens here? Led1On starts at 0. When the Counter value equals 0, three things happen:
¤ LED1 is turned on
¤ LED1On is set to 20
¤ LED1Off is set to 10
When the Counter = 10, LED1 will be turned off.
When the Counter = 20, the sequence repeats.
LED1 is on half the time, off half the time, so the brightness is 50%. This is kind of crude; making it a subroutine (do not call this a sub route. That is gibberish.) would be cleaner.
So now let's add a second LED, operating at the same time the first does it's thing.
Dim LED2On as Longword
Dim LED2Off as Longword
LED1On  = 0
LED1Off = 0
LED2On = 0
LED2Off = 0
Counter = 0
While 1 = 1
        LED1 = 1
   End If
       LED1 = 0
   End If
   If Counter = LED2On then
       LED2 = 1
       LED2Off = 20
       LED2On = 500
   End If
  If Counter = LED2Off then
      LED2 = 0
   End If
    Inc (Counter)
          Counter = 0
    End If
Wend
So now, while LED1 is flashing rapidly on and off to be 50% bright, LED2 is flashing very briefly on and then off for a long period, resulting in a twinkling effect. Two LEDs operating independently in the same loop.
This definitely is not polished code, but will show anybody willing to take a few minutes to understand the code how to use this technique. This loop incrementing up to 4,000,000,000 is going to execute very quickly. The on/off Counter times need to be adjusted to suit the effect desired, and a short delay may need to added at the end of the loop. Also, at the end of the loop, initial values will need to be reset to zero.
The picture shows the process. On and off periods might be set to random numbers. But remember, all actions are based on Counter values. Exactly one delay statement might be added. MrDEB's fading routine can also be adapted to this technique.
I didn't check timing....I was a little off.
With a 20MHz clock, 1,000,000 cycles takes roughly 3.5 seconds. You can adjust the number of counter cycles to be the length of the pattern you want. Note: a slower clock will take longer to run – an 8MHz clock will take about 9 seconds, so each counter Increment is about 9 uSec.
Counter = 0
While 1 = 1
    Inc (Counter)
          Counter = 0
    End If
Wend
LED1On  = 0
LED1Off = 0
Counter = 0
While 1 = 1
        LED1 = 1
   End If
       LED1 = 0
   End If
    Inc (Counter)
          Counter = 0
    End If
Wend
¤ LED1 is turned on
LED1On  = 0
LED1Off = 0
LED2On = 0
LED2Off = 0
Counter = 0
While 1 = 1
        LED1 = 1
   End If
       LED1 = 0
   End If
       LED2 = 1
       LED2Off = 20
       LED2On = 500
   End If
      LED2 = 0
   End If
    Inc (Counter)
          Counter = 0
    End If
Wend
You put a lot of effort into that explanation let's hope it's not wasted.
I'm quite sure it's an absolute waste of effort, but I'm a champion of lost causes.
an interesting method to dim an led.
I will give it a try and post the code.
As for yesterday, our internet was on/off all day.
Yep. Hit another one clean out of the park! Right over his head!
Got to love baseball season.
hate to tell you this but it dos not dim. The ratio of on time vers off time stays the same post 108 works very well. Give it a try. Thanks
*  Date    : 5/25/2022                                                      *
*  Version : 1.0                                                            *
*  Notes   :        *
Device = 18F43K22
Clock = 8
// hardware
Dim INDEX  As LongWord  //4294967295
Dim m As Byte
Dim w As Byte
Dim x As Byte
Dim y As Byte
Dim z As Byte
Dim Bright_1 As LongWord        // a wider range of settings FOR A SMOOTHER TRANSITION
Dim Dimmer_1 As LongWord
Dim Bright_2 As LongWord        // a wider range of settings
Dim Dimmer_2 As LongWord
Dim Counter As LongWord
Dim LED1On As LongWord
Dim LED1Off As LongWord
dim led1 as porta.0
main:
// init hdw
               // LED port - all outputs 2 LEDs per port in parallel 330 ohm resistor
TRISA = 0      // SET ALL PORTS AS OUTPUTS
TRISB = 0
TRISC = 0
TRISD = 0
TRISE = 0
   PORTE=%000         //TURN OFF ALL PORTS
   PORTD=%00000000
   PORTC=%00000000
   PORTA=%00000000
   PORTB=%00000000
LED1On  = 0
LED1Off = 0
Counter = 0
While 1 = 1
   If Counter = LED1On Then         //first pass led1 = 0
        LED1 = 1                    // led1 is on
        LED1Off = Counter + 10      //first pas led1 = 10
   End If
   If Counter = LED1Off Then
       LED1 = 0
   End If
    Inc (Counter)
    If Counter > 4000000000 Then  //   4000000000
          Counter = 0
    End If
Wend
