SMT Tantalum Capacitor Code Help
mr_sd
Hi there.
I have a Dell XT tablet pc which has just given up on me.
I find when I press down on one of the capacitors on the motherboard, it boots!
I'm thinking faulty capacitor / broken track.
I want to replace the capacitor to be safe but (having never used SMT capacitors before) am unsure of the coding.
The capacitor reads:
]ko[
227
6k
733
The "k" in "6k" has a bar above and below it.
I think this is a 220uF capacitor.
From pictures, I think it is a D Type casing.
I am unsure of the tollerance and voltage ratings though.
Any help would be appreciated.
Also does anyone know any websites in the UK that would stock this.
Kind regards,
Rich.
A dry joint perhaps...a quick re-soldering job may be better than trying to remove and replace the cap.
Yeah, I will give that a go, but I'm more than aware that capacitors are the primaty cause of motherboard failure.
I have found some more details
KO stands for Kemet Organic
227 is 220uf
I think 6k means 6.3v Kemet
733 is the 33rd week of 2007.
Now how do i find the tollerance and the ESR - and will this be important as Kemet have about 6 different types in the same package size.
See https://docs-europe.electrocomponents.com/webdocs/0923/0900766b80923fcc.pdf
Cheers, Rich.
Correct.
The D case has dimensions: 7.3 x 4.3 mm.
'k' usually stays for 10% tolerance.
As far as the nominal voltage is concerned, different manufacturers use different markings. 220uF-10 V is easily available in case D, haven't seen higher values for 220 uF.
