A little project that's been sitting on the back burner for several years is an LED bar graph display for a certain special application. For maximum resolution, I'd like to use a large number of very small SMT LEDs, maybe 0402 package. If I could create a viable PCB, there might be a small market amongst fellow hobbyists to use these to replace a display in some obsolete equipment. (I'm being deliberately vague here because I don't want to give away my trade secrets.)
I would have to get the complete board built, with all of the components mounted on it, not just a bare board. So, I need to find a company that can build the whole board in small runs for a reasonable price. Secondly, I probably need advice in designing the PCB layout, because the alignment of the LEDs is important, so that the row of LEDs in the bar graph isn't uneven. I understand that as long as the solder pads are designed with the proper dimensions then the components should be self-aligning. Unfortunately, at this point I'm out of my comfort zone, because my past PCB design experience has been limited to hobby grade toner transfer boards designed with a generic CAD drafting (non-PCB) program.
My immediate concerns are that while I could design some sort of circuit board in Eagle or KiCad (I have both), I might end up designing something that couldn't be practically manufactured. Is there any source of design guidelines for practical PCB design readily available?
