SMPS power factor correction
Mosaic
I am getting around 0.68 PF from a Meanwell clone 36VDC 350W SMPS.
Is there anything reasonably simple to be done to improve that P.F.?
There are passive power factor correction methods for power supplies, but they usually are integrated into the front end. Other than a very large series inductor, there is nothing "reasonably simple" that can be done external to the supply.
ak
Simple answer is NO.
Adding that much inductance to a full wave rectifier will cause it to average not peak filter.
With out inductor; 110Vin ac, 150Vout dc.
With inductor; 110Vin ac, 110Vout dc.
No, I'm talking about an inductor *before* the input bridge, in series with the incoming AC line. The question was about doing something simple, and I took that to mean something outside the purchased power supply.
ak
At 350 watt/VA why bother unless you are running 50 - 100 of these units at once?
If you are running that many of these power supplies at once then going to a centralized PFC system would be a better solution.
