SMD LED's - Vf, If
arhi
I have bunch of SMD LED's (mostly green and red, few white and few blue ones).. some are 0.6 some 0.8mm
The problem I have is, I have no idea what the voltage dropout is for those, what is the optimal and what is the maximal forward current, how long I can drive them with maximal forward curent .. etc etc ..
Is there any way to measure this values (Vf I can probably measure with voltmeter but how to know optimal forward current) ? Is there "standard" for SMD LED's or trial & error is the only way to go?
With out looking most small LEDs use a maximum of 20mA.
Go to digikey.com
Part number search window type in “LEDs”
Page down to Optoelectronics and click on LEDs -<75mA
You can select which type of LED to look for. Under Package/Case I selected 0805 just to pick a small SMT type. Click on Apply Filter.
I selected RED and Applied the Filter and now there are only 137 red 0805 LEDs.
To get to a data sheet faster I chose the Manufacture of Rohm.
At this point it looks like a RED LED needs 1.7 to 2 volts with a maximum of 20mA.
Select a part-number. Select Datasheets.
Now I see a datasheet for a series of Rohm LEDs in a small SMT case.
The shorter the wavelength the colour the higher the forward voltage will be.
Red will be between 1.7 to 2V.
Green will be between 2 to 3.3V depending on whether it's a blueish green or yellowish green.
Blue and white will be from 3 to 3.6V.
The forward voltage also varies depending on the current, for example a red LED might have a Vf of just 1.6V at 500:mu:A and 1.9V at 20mA.
