hi all
if someone could answer the following questions that would be great.
i am trying to make a preamp for a pcb microphone. I am doing some simulations at the mo on orcad and i am having some trouble getting what i require. I found this circuit on the web.
Now i am using a different opamp and DC voltage in the simulation because i dont have the model for the opamp it says to use in the circuit. Anyway i need the circuit to perfrom over the audio range (upto 20khz) and it must run from 3.3V or less. I imagine it will need a failry fast slew rate for audio aswel. If anyone has a good choice please let me know of the IC. the ic from the schematic says to use a TLC727.
Attached is the circuit and time analysis simulation. What i noticed is the output is fairly distorted. Is this becasue of the op-amp? i am assuming it is becasue the 741 is not that fast. Also orcad does not like open ended components therefore the output from the capacitor is tied to ground via a large resistor. Would this cause distortion? in reality i would not include that part if i was to make the circuit. its only for orcads simulation.
also although the circuit is working i was wondering why the ac signal is not fed into the + terminal of the opamp. Basically a non inverting amplifier and the ac signal fed into the +ve terminal via the two resistors in series. Ive tried that circuit and it didnt work. ive also attached my attempt at the circuit.
thanks
thanks
