small help for my pic project please
wejos
My problem is, aside from I'm new to electronics, I also live in the remote part of the Philippines, where electronic parts are really scarce. How remote? very very remote. Out in the woods :eek: Now, I bought this replacement part because the other one is not available, but I'm not sure if I should use it.
Here's the schematic diagram:
Here's what I think I should have bought (4 MHz ceramic resonator):
And here's what they only have (labeled 4.000 MHz):
The pins were different. The one I bought only has 2 pins when it should have 3.
Is it okay to use this? and do these pins have polarity? should I just ignore the GND connection?
And one last final thing. What does VCC there mean? does it mean +6v?
Thanks a lot in advance
It's hard to tell but it looks like a 2 pin resonator. Should be fine but you'll need to add a couple of 33pf caps one from each leg to ground
VCC is 5v, 4 AA NiMH will be about 5v when fully charged.
Rechargeable batteries?
I have a Cannon AC-DC adaptor, 3-12v 500ma
It has 4.5 and 6 volts selection
Which one should I use?
Thank you very much for your help. I'll buy those 33 pf tomorrow :D
4.5V should be fine, but you'll need more than 500ma if you plan on running more than a couple of servo motors.
Okay thanks.
i'm just trying light up some LED and switch one or two 12v relay.
You were really a BIG help. Thanks again man.
I'm a newbie :D
Very interesting stuff here
