I want to build a neural network out of modules (i.e. blocks).
Each module has 6 sides with one electrode on each side. The modules are stacked together so that one electrode on one module touches one electrode on another module.
Each electrode acts as both an input and an output for the simple analog circuit inside each module. I need to split the input and output at each electrode so I don't get feedback within the module circuit.
ah, good question Torben.
Initially the modules would be be connected to and powered by positive and negative/earth rails.
Ultimately, I would hope to power the modules wirelessly or perhaps using an "Avramenko one wire circuit" (see this discussion for details).
My idea is a fully analog neural network, so I don't want to use a UART or any other digital transmission device.
If it's fully analog then any connections depend entirely on exactly what it is.
Although it sounds a completely useless idea to be honest?.
sorry, I don't understand what this means.
Basically this is a toy/tool for investigating analog neural networks. It may turn out to be completely useless, but I will not be convinced until either a) someone provides a compelling reason why it wouldn't work, or b) I test it out myself.
you might need dozens, hundreds, or even thousands of cells before you get interesting behaviours. an insect has millions, The human brain has billions.
