sine and cosine functions with microchip
Steve311
Hello all, been a while since I’ve programmed but looking for insight on sine and cosine functions when using a pic? I’m familiar with the pic16F6xx series but that’s about it. Easiest and most accurate approach ? TIA
By storing one 45 degree table you can get all 360 degree values. Is 8 bit enough resolution?
x=radius;
y=0;
m=1/256 or other fraction which makes a small number.
do forever
{ x=x - y*m;
y=y + x*m;
will trace out an almost perfect circle.
Can be done with only adds and shifts if the denominator of the small fraction is a power of two...
From the Cordic algorithm.
I first did this in Assembler on a PDP-8...
x=radius;
y=0;
do forever
{ x=x - y*m;
y=y + x*m;
is that cordic boiled down? or something else?
edit: durrr, how did i miss the last sentence.
A good way to think about the cordic algorithm is it's like those nail and string patterns that form curves.
I use a small routine that has 15 table entries and draws tiny lines between each 3° I use it in virtually all my display's it is for 90° but I use it for any angle..
C:
long cosine(int ang)
    int x,y;
    long tmp,count=0;
    if(ang > 900) ang = 900 -(ang - 900);
    for(x=0;x<30;x++)
        y += 2;
        tmp = ReadTable(y);
        if(ang == 30)
            count += tmp;
            count = 4000 - count;
            return count;
        if(ang < 30)
            count += (tmp/30)* ang;
            return count;
        count += tmp;
        ang -= 30;
    return 0;
The lookup table is percentages of 4000 each 3° is determined and added to produce the fraction of 4000... Because I use fixed math I use this to work out radius from angle The angle is 0 ~ 900 and the length is multiplied by the answer and divided by 4000 !
Works for me..
