Simple Field Strength Meter [Deleted]
ElectroMaster
Administrator
ElectroMaster submitted a new article:
Simple Field Strength Meter - This Field Strength Meter is simple and also quite sensitive. It uses an ordinary digital voltmeter
This Field Strength Meter is simple and also quite sensitive. It uses an ordinary digital voltmeter to measure signal strength. The VM should be set to the lowest dc volts range for maximum sensitivity. This is normally 200mV DC for most meters.
I have tried this at VHF and was quite pleased with the results. L1 was 7 turns on a quarter inch former with ferrite slug. This covered the UK FM band. A digital multimeter, as opposed to an analogue signal meter has several advantages in this...
Read more about this article...
