SHT11 wrong readings
bulldozer
New to C-Programming here.....
I based most of my code around stuff I found online, like ghostman's.
Compiler is Hi-Tech. The LCD prints out 15.40 C when it should be room temp (~22C). Humidity is obviously also wrong because it is a function of temperature.
The LCD does change values when I hold my finger to it for instance, so I know that the communication is fine. PIC16f887 is running 4 MHz.
I think the problem is with the math and maybe the bit size..I'm a bit(:)) confused there
Any suggestions?
#include <delay.h>
#include <lcd.h>
#include <htc.h>
__CONFIG(INTCLK & WDTDIS & PWRTEN & MCLRDIS & UNPROTECT & DUNPROTECT &
BORDIS & IESOEN & FCMDIS & LVPDIS & DEBUGEN & WP2);
#include <math.h>
#include <stdio.h>
enum {TEMP,HUMI};
#define TRIS_DATA TRISC5    //data port condition: input/output
#define TRIS_SCK  TRISC4
#define DATA RC5         //SHT11 DATA pin
#define SCK RC4          //STH11 SCK pin
#define noACK 0
#define ACK 1
//adrress commands from Sensirion   //adr ||command || r/w
#define STATUS_REG_W 0x06           //000    0011       0
#define STATUS_REG_R 0x07           //000    0011       1
#define MEASURE_TEMP 0x03           //000    0001       1
#define MEASURE_HUMI 0x05           //000    0010       1
#define RESET 0x1e                  //000    1111       0
//Constants used for SHT Humidity Measurment
#define C1 -4.0
#define C2 0.0405
#define C3  -0.0000028
//Constants used for SHT Temeperature Measurment (14 Bit)
#define D1 -40.0
#define D2 0.01
// constant use for SHT True Humidity Measurement (12 Bit)
#define T1  0.01
#define T2  0.00008
// writes a byte on the Sensibus and checks the acknowledge
unsigned char s_write_byte(unsigned char value)
   unsigned char i,error=0;
   TRIS_DATA = 0;   //SHT11 WRITE...make DATA-line output
   SCK=0; //initial state
   for (i=0x80;i>0;i/=2) //shift bit for masking
     DelayUs(5);
     if (i & value)
         DATA=1; //masking value with i , write to SENSI-BUS
     else
         DATA=0;
     SCK=1; //clk for SENSI-BUS
     DelayUs(5);   //pulswith approx. 5 us
     SCK=0;
   TRIS_DATA = 1;    //SHT11 READ..make DATA-line input
   DelayUs(5);
   SCK=1; //clk #9 for ack
   DelayUs(5);
   error = DATA; //check ack (DATA will be pulled down by SHT11)
   SCK=0;
   return error; //error=1 in case of no acknowledge
// reads a byte from the Sensibus and gives an acknowledge in case of "ack=1"
unsigned char s_read_byte(unsigned char ack)
   unsigned char i,val=0;
   //DATA=1; //release DATA-line
     DelayUs(5);
     if (DATA)
     val=(val | i); //read bit
     DelayUs(5);
     SCK=0;
   TRIS_DATA = 0;    //make DATA-Line output
   DATA=!ack;         //in case of "ack==1" pull down DATA-Line
   SCK=0;
   TRIS_DATA=1;
   return val;
void s_transstart(void)
// generates a transmission start
//       _____         ________
// DATA:      |_______|
//           ___     ___
// SCK : ___|   |___|   |______
   TRIS_DATA = 0;   //SHT11 WRITE - DATA_Line output
   DATA=1;
   SCK=0;   //Initial state
   DelayUs(5);
   SCK=1;
   DelayUs(5);
   DATA=0;
   DelayUs(5);
   SCK=0;
   DelayUs(5);
   SCK=1;
   DelayUs(5);
   DATA=1;
   DelayUs(5);
   SCK=0;
void s_connectionreset(void)
// communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
//       _____________________________________________________         ________
// DATA:                                                      |_______|
//          _    _    _    _    _    _    _    _    _        ___     ___
// SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______|   |___|   |______
   unsigned char i;
   DATA=1; SCK=0;  //Initial state
   for(i=0;i<12;i++) //12 SCK cycles....more than 9 for safe being
	 SCK=1;
     DelayUs(5);
     SCK=0;
   s_transstart(); //transmission start
void main()
// 1. Define Ports
// 2. Initalize LCD and reset connection to sensor
// 3. While Loop: calculate humidity [%RH] and temperature []C in 12BIT mod
// 4. print temperature, humidity, dew point
	unsigned char error,checksum, byte_1, byte_2;
    int lValue_Temp, lValue_Hum, i;
    int fTemp_true,Rh_lin,fRh_True;
 	   //CONFIG1 = 0b1110000011000101;
 	   OSCCON = 0b01100101;
 	   OSCTUNE = 0b00001111;
	   TRISD = 0x00;
       TRISA = 0x00;
       TRISB = 0x00;
       TRISC = 0x00;
       INTCON = 0x00; //disable interrupts
       ANSEL=0x00; //Digital AN[0:7]
       ANSELH = 0x00; //Digital AN[13:8]
       ADCON0=0; //turn off A/D
   lcd_init();
   s_connectionreset();
   DelayUs(20);
  // s_write_statusreg(0x03); //low resolution data
   while(1)
      Measure Temperature
	s_write_byte(MEASURE_TEMP); //measure Temperature
	while (DATA); //wait until SHT11 ends measurements
	//Save highest byte read, in RAM
	byte_1 =  s_read_byte(ACK);
	//Save lowest byte read, in RAM
	byte_2 =  s_read_byte(noACK);
    lValue_Temp = (byte_1*256) + byte_2; //combines two bytes (8 bit) into a 16 bit (word)
      temperature calculation
    fTemp_true = (D1+(D2*lValue_Temp)*100);
     Meausure Humidity
    s_connectionreset(); //Reset Sensor BUS
	s_write_byte(MEASURE_HUMI); //measure Humidity
	byte_1 =(unsigned char)  s_read_byte(ACK);
	byte_2 = (unsigned char) s_read_byte(noACK);
    lValue_Hum = ((unsigned char)byte_1*256) + (unsigned char)byte_2; //combines two bytes (8 bit) into a 16 bit (word)
      Humidity calculation
    Rh_lin = (C1+(C2*lValue_Hum)+(C3*lValue_Hum*lValue_Hum));
    fRh_True = (((fTemp_true-25)*(T1+(T2*lValue_Hum)))+Rh_lin)*100;
    if((fRh_True/100)>100) fRh_True=10000;
    //if((fRh_True/100)<0.1)fRh_True=0.001;
      Print to LCD
    char buffer[20];
    sprintf(buffer, "T=%d.%d C H=%d.%d %%", fTemp_true/100, fTemp_true%100, fRh_True/100, fRh_True%100);
	lcd_goto(0);	// select first line
	lcd_puts(buffer);
//----------wait approx. 0.8s to avoid heating up SHTxx----------------------
     for(i=0;i<2000;i++)
        DelayUs(8000);
i will post better code for you soon as i get my pc back online, with the sht sensors tempreture and humidity are seperate. so its more than likely humidity is right even if temp is wrong, you need to make sure also that you dont read the sensor more than about once every 1.5 seconds, i know the datasheet says something like 750 Ms but anything lower than 1.5 seconds seems to lead to self heating of the sensor.
Got it to work guys.....problem was the compiler. I had to disable all optimization.
I discovered this while going through a for loop and "i" would clearly go over 12 and it would still be in the loop!
Honestly, this was a very hard "bug" to find and I hope no one runs into this.
Hello! I am trying to display the temp and humidity on an 3310 display.
But I get really weird readings...
Great project by the way...
Can you tell me what you did so that you got good readings?
This is my code, after I modified bulldozer's :
#include "delay.h"
#include "lcd3310.c"
#include <htc.h>
__CONFIG(WDTDIS & PWRTEN & UNPROTECT & BORDIS & LVPDIS & DEBUGEN & WP2 & DUNPROT);
#include <math.h>
#include <stdio.h>
enum {TEMP,HUMI};
#define TRIS_DATA TRISB1    //data port condition: input/output
#define TRIS_SCK  TRISB0
#define DATA RB1         //SHT11 DATA pin
#define SCK RB0          //STH11 SCK pin
#define noACK 0
#define ACK 1
#define C1 -4.0
#define C2 0.0405
#define D1 -40.0
#define D2 0.01
#define T1  0.01
#define T2  0.00008
     DelayUs(5);
     if (i & value)
     else
         DATA=0;
     SCK=0;
   DelayUs(5);
   DelayUs(5);
   SCK=0;
     DelayUs(5);
     if (DATA)
     DelayUs(5);
     SCK=0;
   SCK=0;
   TRIS_DATA=1;
   return val;
//       _____         ________
// DATA:      |_______|
//           ___     ___
   DATA=1;
   DelayUs(5);
   SCK=1;
   DelayUs(5);
   DATA=0;
   DelayUs(5);
   SCK=0;
   DelayUs(5);
   SCK=1;
   DelayUs(5);
   DATA=1;
   DelayUs(5);
   SCK=0;
// DATA:                                                      |_______|
   unsigned char i;
	 SCK=1;
     DelayUs(5);
     SCK=0;
void initialize(void)
	lcd_init();		//initialize 3310LCD
	lcd_clear();	//clear screen
void afisare (int numar, unsigned char linia, unsigned char coloana)
	if(numar>99)
		display_digit(linia,coloana,(numar/100)%10);                //sute
		display_digit(linia,coloana+10,(numar/10)%10);                 //zeci
		display_digit(linia,coloana+20,numar%10);                      //unitati
	else
		lcd_gotoxy(coloana-1,linia-1); lcd_puts("  ");
		lcd_gotoxy(coloana-1,linia); lcd_puts("  ");
void main()
// 1. Define Ports
// 	   OSCCON = 0b01100101;
 //	   OSCTUNE = 0b00001111;
	   TRISD = 0x00;
       TRISA = 0x00;
       TRISB = 0x00;
       TRISC = 0x00;
  //     ANSEL=0x00; //Digital AN[0:7]
  //     ANSELH = 0x00; //Digital AN[13:8]
 	initialize();
   DelayUs(20);
   while(1)
      Measure Temperature
     Meausure Humidity
      Print to LCD
    char buffer[20];
	lcd_puts(buffer);
	afisare( fTemp_true, 1, 30);
	afisare(fRh_True, 3, 30);
     for(i=0;i<2000;i++)
        DelayUs(8000);
If anyone needs the proteus file I will post it, I didn't right now because I only have win rar and it won't let me upload.
I wait for a reply. Thank you in advance!
#include "delay.h"
#include "lcd.h"
#include <htc.h>
#include "math.h"
#include "stdio.h"
#include "serial.h"
enum {TEMP,HUMI};
#define TRIS_DATA TRISB4    //data port condition: input/output
#define TRIS_SCK  TRISB3
#define DATA RB4         //SHT11 DATA pin
#define SCK RB3          //STH11 SCK pin
#define noACK 0
#define ACK 1
#define C1 -4
#define C2 0.0405
#define D1 -40.0
#define D2 0.01
#define T1  0.01
#define T2  0.00008
//PWM Heat Tape
#define HEAT_ON  RB5=1
#define HEAT_OFF RB5=0
     DelayUs(20);
     if (i & value)
     else
         DATA=0;
     DelayUs(20);   //pulswith approx. 5 us
     SCK=0;
   DelayUs(20);
   DelayUs(20);
   SCK=0;
   unsigned char i; int val=0;
     DelayUs(20);
     if (DATA)
     DelayUs(20);
     SCK=0;
   SCK=0;
   TRIS_DATA=1;
   return val;
//       _____         ________
// DATA:      |_______|
//           ___     ___
   DATA=1;
   DelayUs(20);
   SCK=1;
   DelayUs(20);
   DATA=0;
   DelayUs(20);
   SCK=0;
   DelayUs(20);
   SCK=1;
   DelayUs(20);
   DATA=1;
   DelayUs(20);
   SCK=0;
// DATA:                                                      |_______|
   unsigned char i;
	 SCK=1;
     DelayUs(20);
     SCK=0;
    float prev_Temp;
    float prev_Hum;
    float temp_true=23, Rh_lin, RH_true=50,dew_point=10,p;
    float k;
void main()
// 1. Define Ports
    int lValue_Temp, lValue_Hum,i;
    float k;
   	char buffer[20];
    long int time=0;
 	unsigned char error,checksum, byte_1, byte_2,byte_0;
       TRISA = 0x00;
       TRISB = 0x00;
       TRISC = 0x00;
   lcd_init();
   lcd_clear();
   init_comms();
   DelayUs(20);
   while(1)
      DewPoint Calculation
	if(temp_true!=NULL){
	k = (log10(RH_true)-2)/0.4343 + (17.62*temp_true)/(243.12+temp_true);
   	//k+= (17.62*temp_true)/(243.12+temp_true);
	dew_point = 243.12*k/(17.62-k);
	  prev_Temp = temp_true;
	   prev_Hum = RH_true;
      Measure Temperature
	while(DATA);
	//while (DATA); //wait until SHT11 ends measurements
    temp_true = (D1+(D2*lValue_Temp));
     Meausure Humidity
	for(i=0;i<9999;i++)
		{if (DATA==0) break;}
	if (DATA=1) s_connectionreset();
    lValue_Hum = (byte_1*256) + byte_2; //combines two bytes (8 bit) into a 16 bit (word)
    RH_true = (((temp_true-25)*(T1+(T2*lValue_Hum)))+Rh_lin);
    if((RH_true)>100) RH_true=100; //Ceiling for RH measurment
    if((RH_true)<0.1) RH_true=0.1; //Floor for RH measurment
      Print to LCD
    sprintf(buffer, "T=%.2f C RH=%.2f %%", temp_true, RH_true);
	lcd_goto(0x00);	// select first line
	lcd_puts(buffer);
	sprintf(buffer, "Dew Point= %.2f C", dew_point);
	lcd_goto(0x40);
	lcd_puts(buffer);
	lcd_goto(0x14);
	sprintf(buffer,"PREV T=%.2f C",prev_Temp);
	lcd_puts(buffer);
	lcd_goto(0x54);
	sprintf(buffer,"PREV RH=%.2f %%",prev_Hum);
	lcd_puts(buffer);
      Print to SERIAL
  time+=10;
  sprintf(buffer,"\rT= %.2f   RH= %.2f   Time= %d   ",temp_true,RH_true,time);
  puts(buffer);
        DelayMs(220);
        DelayMs(220);
:)Dear,
wolfei send me complete code for SHT11 interfacing with PIC16f887
along with proteus file, Circuit diagram, Simulation Results & calculations
Regards:rolleyes:
