should i be using overcurrent protection for this project
doubleM
i am powering 2 sets of 3 5mm leds with an ac adapter. they are wired in parallel with resistors. the output dc voltage is 12v and the current output is only 500 mA. ive left them on all day without any issues. they get a little warm but not hot. its not really enough power to cause a disaster or catch on fire, but i have no fuse on it or overcurrent protection.
the thing is its in a product i may be selling to people. so i dont want to take chances. would say a 1 amp bus fuse do it? or just not worry about it?
You do not state the current rating of your AC adaptor.?
If for example it was rated at max of 1Amp, its most likely a 1Amp fuse would never blow.!
As the parallel LED's only draw 500mA, you could use a series 750mA fuse, IF the AC adaptor is rated at 1Amp or more.
Which component 'failure' in your project are you concerned about, the resistors or the LED's.???
Unclear. What is a 'set' here? Is it 3 LEDs in series? Is there one resistor per set in series with 3 LEDs? Are the 2 sets in parallel? What is the current through each LED?
