Seven segment display using a 16f88
GreenP
Hi
I'm pretty new to these PIC things and i would like to turn two seven segment displays on, showing different numbers depending on other variables (not shown in the code below) the seven segment displays are connected to portB and the bases of two transistors are connected to bits 2 and 3 on portA, these transistors turn the cathodes for the displays on and off.
I can build the project and simulate it using MPLAB SIM, I can annimate it using the ICD2 incircuit debugger and every thing is OK as soon as I run the program in real time it stops at the goto main and
movlw b'00000000'
movwf portA
lines of code
Could anyone help as i would be very greatful
GreenP
Here is My code:
;30/10/07 ;
;Targeting the 16f88 device
;list p=16f88 ;
TMRO equ 01h ;TMRO address
status equ 03h ;status register address in bank 0
trisA equ 85h ;trisA address in bank 1
trisB equ 86h ;trisB address in bank 1
portA equ 05h ;portA address in bank 0
portB equ 06h ;portB address in bank 0
ANSEL equ 9Bh
PCL equ 02h ;program counter address
OPTION_REG equ 81h ;options register sddress
OSCCON equ 8Fh
DELAYONE equ 20h ;address in general purpose register for 100 counts for the delay
org 0h ;?
goto START
org 10h ;?
INT
;declaring the ports
bsf status,5 ;setting bit 5 in status register1 so the program is looking at memory bank 1
clrf ANSEL
clrf trisA
clrf trisB
movlw b'00100000' ;putting the literal value 00000000 into the working register
movwf trisA ;moving the value 00000000 into trisB sets up portB as all outputs
movlw b'00000000' ;putting the literal value 00000 into the working rerister
movwf trisB ;moving the value 00000 into trisA sets up portA as all outputs
;setting up the options register for TMRO
movlw b'10000000' ;moving the literal value into the working register and then into the
movwf OPTION_REG ;options register so as to set up the prescaler for TMRO
movlw b'01101000'
movwf OSCCON
STABLE
btfss OSCCON,2 ; INTOSC frequency stable?
goto STABLE ; no, branch and wait
bcf status,5
return
DELAY
clrf portA
clrf portB
movlw b'00000011' ;moving the literal value decimal 100 into the working register
movwf DELAYONE ;and then into the count 100 register so timer can count up to 100
bsf portA,0
call DISPLAY_1
DELAY_1
decfsz DELAYONE
goto DELAY_1
clrf portA
clrf portB
movlw b'00000010'
movwf portA
call DISPLAY_2
DELAY_2
decfsz DELAYONE
goto DELAY_2
clrf portA
clrf portB
return
DISPLAY_1
movlw b'1101111' ;code for 0
movwf portB
return
DISPLAY_2
movlw b'1111101' ;code for 6
movwf portB
return
START
call INT
MAIN
call DELAY
goto MAIN
END
You might have a look at my seven segment tutorial - sounds like it will do just what you want!.
BTW, if you post code use the 'code' button to maintain it's formatting (it's on the 'advanced' setting.
