Setting up CCP PWM in PIC16F628A
finally I got nigels code hacked. Better said would be butchered. But the cool thing is I can choose which light of the 4 I have on my board that I would like to light up. Here is the code if you have any suggestions or comments. Next step is ADC so I can use a potentiometer to change the byte. Then I will have a 1 channel IR airplane system.
Transmitter code
;transmitter for 12f675
	list P=12f675
#include <p12f675.inc>
	__config _INTRC_OSC_NOCLKOUT & _BODEN_OFF & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CPD_OFF & _CP_OFF
	ERRORLEVEL -302
	cblock		0x20
	count1, counta, countb, count, bits, data1
	endc
	bsf	STATUS,RP0		;bank 1
	clrf	ANSEL
	movlw	0x30
	movwf	TRISIO		;make bit 4 and 5 inputs
	bcf	STATUS,RP0
	movlw	0x00
	movwf	GPIO
	movlw	0x07		;turn off comparitors
	movwf	CMCON
readswitch
	btfss	GPIO,5
	call	switch1		;check if switch one is pressed
	btfss	GPIO,4
	call	switch2		;check switch two
	goto	readswitch
switch1
	movlw	0x01		;send a one to the receiver
	call	xmit
	retlw	0x00
switch2
	movlw	0x02		;send a two to the receiver
	call	xmit
	retlw	0x00
startbit
	movlw	d'92'		;start bit
	call	irpulse
	movlw	d'23'
	call	nopulse
	retlw	0x00
xmit
	movwf	data1		;transmit byte assigned by the switch that was pressed
	movlw	0x07
	movwf	bits
	call	startbit
loopsendcode
	rrf	data1,1			;send a bit then rotate
	btfsc	STATUS,C	;keep sending bits until a byte is sent
	call	xmit1
	btfss	STATUS,C
	call	xmit0
	decfsz	bits,f
	goto	loopsendcode
	retlw	0x00
xmit1
	movlw	d'46'		;send a one
	call	irpulse
	movlw	d'23'
	call	nopulse
	retlw	0x00
xmit0
	movlw	d'23'		;send a zero
	call	irpulse
	movlw	d'23'
	call	nopulse
	retlw	0x00
irpulse					;38Khz signal on
	movwf	count
irloop
	bsf	GPIO,1
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	bcf	GPIO,1
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	decfsz	count,1
	goto	irloop
	retlw	0x00
nopulse
	movwf	count		;38Khz signal off
irloop2
	bcf	GPIO,1
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	decfsz	count,1
	goto	irloop2
	retlw	0x00
delay27						;delays that I'm not using
	movlw	d'27'
	movwf	count1
d1
	movlw	0c7
	movwf	counta
	movlw	0x01
	movwf	countb
delay1
	decfsz	counta,1
	goto	$+2
	decfsz	countb,1
	goto	delay1
	decfsz	count1,1
	goto	d1
	retlw	0x00
	end
Receiver code
;receiver 12f675
	list P=12f675
	ERRORLEVEL -302
	cblock		20h
	BH,BL,wait,del_clk1,del_clk2,run,runn,PWM,startcounter
	startcounter2,zcounter,zcounter1,zcounter2,usefuldata,timer
	endc
	clrf	ANSEL
	movlw	0x04
	movwf	TRISIO		;make bit 2 an input
	bcf	STATUS,RP0
	movwf	CMCON
main
	movlw	0xff		;set PWM timer
	movwf	timer
	clrf	PWM
	clrf	usefuldata	;clear usefull data file and outputs
	movlw	0x00
	movwf	GPIO
	call	prestartbit	;get the IR information
	call	dosomething	;use the IR information
	goto	main
dosomething
	movf	usefuldata,0	;turn on a led that corresponds to bits send by IR
	movwf	GPIO
	decfsz	timer,1
	goto	dosomething
	retlw	0x00
;	movf	usefuldata,0	;PWM not currently in use
;	movwf	PWM
;bithigh
;	bsf		GPIO,0
;	decfsz	PWM,1
;	goto	bithigh
;	bcf		GPIO,0
;	movf	usefuldata,0
;	movwf	PWM
;bitlow
;	incfsz	PWM,1
;	goto	bitlow
;	decfsz	timer,1
;	goto	dosomething
;	retlw	0x00
prestartbit
	btfss	GPIO,2			;wait for high
	goto	prestartbit
prestartbit2
	movlw	0x03
	movwf	startcounter2
	btfsc	GPIO,2
	goto	prestartbit2	;wait for low
reset
	movlw	0xbf
	movwf	startcounter
startbit
	decfsz	startcounter,1
	goto	startbit
	btfss	GPIO,2
	goto	$+2
	goto	prestartbit2
	decfsz	startcounter2,1	;wait for start bit to finish
	goto	startbit		;keep starting over if not a start bit
readdata
	btfss	GPIO,2			;wait to finish left over low
	goto	readdata
waitfordata
	btfsc	GPIO,2			;wait for high between pulses to end
	goto	waitfordata
writedata
	movlw	0xb0			;cound down then see if it was long enough to be a 1
	movwf	zcounter
	movwf	zcounter1
	movwf	zcounter2
writebit0
	decfsz	zcounter,1
	decfsz	zcounter1,1
	decfsz	zcounter2,1
	goto	writebit0
	btfsc	GPIO,2			;if not a 1 then go to wait for high to finish
	goto	bit0wait2		;if a 1 then set that bit and continue
	bsf		usefuldata,0
bit0wait
	btfss	GPIO,2			;wait for low to finish
	goto	bit0wait
bit0wait2
	btfsc	GPIO,2			;wait for high to finish
	goto	bit0wait2
	movlw	0xb0			;continue until all bits in the
	movwf	zcounter		;usefull data file have been written
	movwf	zcounter1
	movwf	zcounter2
writebit1
	decfsz	zcounter,1
	decfsz	zcounter1,1
	decfsz	zcounter2,1
	goto	writebit1
	btfsc	GPIO,2
	goto	bit1wait2
	bsf		usefuldata,1
bit1wait
	btfss	GPIO,2				;change to btfss
	goto	bit1wait
bit1wait2
	btfsc	GPIO,2
	goto	bit1wait2
	movlw	0xb0
	movwf	zcounter
	movwf	zcounter1
	movwf	zcounter2
writebit2
	decfsz	zcounter,1
	decfsz	zcounter1,1
	decfsz	zcounter2,1
	goto	writebit2
	btfsc	GPIO,2
	goto	bit2wait2
	bsf		usefuldata,2
bit2wait
	goto	bit2wait
bit2wait2
	btfsc	GPIO,2
	goto	bit2wait2
	movlw	0xb0
	movwf	zcounter
	movwf	zcounter1
	movwf	zcounter2
writebit3
	decfsz	zcounter,1
	decfsz	zcounter1,1
	decfsz	zcounter2,1
	goto	writebit3
	btfsc	GPIO,2
	goto	bit3wait2
	bsf		usefuldata,3
bit3wait
	goto	bit3wait
bit3wait2
	btfsc	GPIO,2
	goto	bit3wait2
	movlw	0xb0
	movwf	zcounter
	movwf	zcounter1
	movwf	zcounter2
writebit4
	decfsz	zcounter,1
	decfsz	zcounter1,1
	decfsz	zcounter2,1
	goto	writebit4
	btfsc	GPIO,2
	goto	bit4wait2
	bsf		usefuldata,4
bit4wait
	goto	bit4wait
bit4wait2
	btfsc	GPIO,2
	goto	bit4wait2
	movlw	0xb0
	movwf	zcounter
	movwf	zcounter1
	movwf	zcounter2
writebit5
	decfsz	zcounter,1
	decfsz	zcounter1,1
	decfsz	zcounter2,1
	goto	writebit5
	btfsc	GPIO,2
	goto	bit5wait2
	bsf		usefuldata,5
bit5wait
	goto	bit5wait
bit5wait2
	btfsc	GPIO,2
	goto	bit5wait2
	movlw	0xb0
	movwf	zcounter
	movwf	zcounter1
	movwf	zcounter2
writebit6
	decfsz	zcounter,1
	decfsz	zcounter1,1
	decfsz	zcounter2,1
	goto	writebit6
	btfsc	GPIO,2
	goto	bit6wait2
	bsf		usefuldata,6
bit6wait
	goto	bit6wait
bit6wait2
	btfsc	GPIO,2
	goto	bit6wait2
	movlw	0xb0
	movwf	zcounter
	movwf	zcounter1
	movwf	zcounter2
writebit7
	decfsz	zcounter,1
	decfsz	zcounter1,1
	decfsz	zcounter2,1
	goto	writebit7
	btfss	GPIO,2
	bsf		usefuldata,7
	nop
	retlw	0x00
	end
If anyone has a moment could you explain or draw a small picture of how the potentiometer hooks up to the PIC for doing ADC. I hooked one up and let some smoke out. Something like one leg to plus one leg to minus and the swiper to the PIN? Thanks
