What is the limit of the degree of servo movement you need from center then? The limits of the servo won't help you much if they're not within the movement range you need.
Good morning guys back at it again. OK this is what I am trying to do. When power is first applied to the system I want the servo to travel to the 1.0ms position and wait for the momentary switch to be activated. When the momentary reset button is pushed I want the servo to travel to the 2.0ms position then return to the 1.0ms position and then go to sleep waiting til the momentary button is pushed again. Forget about the 1.5ms position. Can this be done with the coding.
