I can't seem to get a definitive answer on this.
Suppose I have three identical NiMH rechargeable batteries. I take the first two and make a parallel "pack" (both positives connected, and both negatives connected). I will end up with a pack that has the same voltage as one of the batteries, but twice the mAh and twice the current discharge capacity.
Now lets say that I connect this pack in series with a single additional identical NiMH battery. Under load (a load that is close to or at the maximum discharge rate of the batteries), I assume that the voltage will drop as current flows through the batteries. Then I additionally assume that the voltage drop across the parallel pair will be less than the voltage drop across the added third battery due to the differences in their internal resistances. This would lead to a voltage imbalance between the parallel set and the third 'in series" battery which would, I assume, cause additional current to flow from the parallel pair to the third battery.
Then my head starts to hurt as I try to figure out what this scenario means for the third battery.
In some ways it could be imagined as connecting 2 NiMH batteries in series with one of them having twice the mAh rating as the other. What would the actual mAh rating of this pack be and what damage, if any, could I inflict on either battery.
Thanks in advance.
Thanks in advance.
