Serial Output logic inversion?
MikeMl
Most Helpful Member
I used to know this, but I have forgotten. :o
To connect the serial output (TX) from a PIC that has a USART to the SerialDataIn Pin of a computer's serial port requires a logic inversion, right? That is normally provided in a MAX232, which also provides negative level shift.
AFAICR, I have done this before with nothing but a simple inverter operating between 0V and 5V. I know that the RS232 spec expects the logic level to swing below 0V, but it seems to work ok even if it doesn't.
Yes it needs to be inverted. :)
If you need a hardware inverter solution you can use a NPN transistor (as open-collector) with a pullup resistor on it's collector.
