Saving Input state into variable
konradIC13
Hello,
Im having troubles with making this code work on ATmega8, i want to store switch value into variable and later use this variable.
Here is code:
 * Test.c
 * Created: 2012-07-08 16:30:47
 *  Author: Konrad
#define F_CPU 1000000L
#include <avr/io.h>
int main(void)
	char a;
	DDRC &=~ (1<<PC5);		 //PC5 as input
	PORTC |= (1<<PC5);		 //pull up
	DDRC &=~ (1<<PC4);		 //PC4 as input
	PORTC |= (1<<PC4);		 //pull up
	DDRC |= (1<<PC3);		 //output
	PORTC |= (1<<PC3);		 //set as 1
    while(1)
		a = (PINC & (1<<PC5));
		b = (PINC & (1<<PC4));
		if(a&&b==1)			 //if both a and b =1
		PORTC |= (1<<PC3);   //set PC3 output as 1
		else
		PORTC &=~ (1<<PC3);  //set PC3 output as 0
I have switches connected to PC5 and PC4 and led connected to PC3. I want to store values of PC5 switch and PC4 switch in 'a' and 'b' variables and then make them turn led on only when both switches are on (high).
I have problem with storing those values into variable:
Not sure if its right
Also i dont know how to use those values in 'if' function,
Also later
First i see a problem at handling of DDRC.
I would set the complete Port with one declaration.
DDRC=0b00001000; //Would set the Port3 as Output the rest as Input
Do the same with the Pullups and Output by setting:
PORTC=0b00111000;
When setting up a Variable by a logical command the Variable not anytime has a value of 1.
So you had to test the result if it is higher than 1.
if(a!=0)
do_something();
else
do_other();
