RGb LED Controller
wcavanagh
I wonder if someone can help a poor man. I want to colour cycle a RGB LED smoothly through thounds of colours, it will be used to light up a lod etched in glass, so random colours would be great. I have been told PWM is what i need, I have a PICKit1 and a PicstarPlus programmer from Microchip. I am very new to this and just dont know where to start, I have some PIC12F675 Chips. Anyone recomend anything? PLEASE.......
Questions
What language are you programming in and what speed are you going to run the 675 at?
Resc.
Going to use ASM as that seems to be all i can do with MPLAB, going to use the internal 4Meg clock
Info
4mhz will work for 3-channels ok if you use the correct methods for pwm, as for ASM I can't help you on that.
Resc.
Re: Info
Resc.
If he's got the PICKit1 (as he said), it comes with a Lite version of a C compiler - if that helps?.
the best way would be to use a TMR0 interupt, then devide it down depending on what value you should have in a file register for each LED.
The TMR0 registrer at 4mhz u might want to use as a global biasing, at the end of the ISR add a value to the TMR0 register.
Thats a pritty rough outline, but it should work fine, you might find a lot of tweaking is needed to get nice linear values (odds are PWM won't provide a smooth change of light intensity with standard linear values)
