Restarting pic C programming help
Kryten
Hi
Im having trouble finding out what im doing wrong with my code. Im using MPlab with HiTech compiler
#include <htc.h>
 void main (void)
 while (1){
 #if (RA0 == 1 && RA1 ==0)
	RA2 = 1;
	_delay_ms(5);
	RA2 = 0;
#elif (RA0 == 0 && RA1 == 1)
	RA2 = 1;
	_delay_ms(5);
	RA2 = 0;
	_delay_ms(500);
#else
	RA2=0;
I get this error :
Error   [100] ; . unterminated #if[n][def] block from line 28
Can someone pleas tell me what im doing wrong?
You shouldn't be using # as this is a compiler directive. Just use if, else if and else.
When i change my code to this :
#include <htc.h>
 void main (void)
 while (1){
 if (RA0 == 1 && RA1 ==0) 	// if input pin 0 is high and pin 1 low then
	{						// turn pin 2 on delay for 5 ms and turn off agin
	RA2 = 1;
	_delay.ms(5);
	RA2 = 0;
else if (RA0 == 0 && RA1 == 1) // if input pin 1 is high and pin 0 low then
	{						   // turn on pin 2 for 5 ms and off for 500 ms
	RA2 = 1;				   // loop until pin 1 is low
	_delay_ms(5);
	RA2 = 0;
	_delay_ms(500);
else
	RA2 = 0;
I get a lot more errors.
Error   [192] \resp-trig.c; 22.5 undefined identifier "RA0"
Error   [192] \resp-trig.c; 22.17 undefined identifier "RA1"
Error   [192] \resp-trig.c; 24.1 undefined identifier "RA2"
Error   [196] \resp-trig.c; 25.11 struct/union required
Error   [192] \resp-trig.c; 30.1 undefined identifier "RA2"
Error   [196] \resp-trig.c; 31.11 struct/union required
Error   [196] \resp-trig.c; 33.11 struct/union required
Error   [192] \resp-trig.c; 37.1 undefined identifier "RA2"
Im using the 12f629 but cant find a proper .h file for it.. Could that be the reason why my pins wont be accepted?
I might not have been good at doing this at all but I think I need some sort of port declaration, I mean I have to say witch pin is input and output, and set the states as all low or something.
Like I said in the top Im starting back up with C programming Its been almost tow years since I last entered a compiler so I want to get back in there again.
On the 12F629 Microchip renamed portA as GPIO and so you use GPIO3 etc as the pin definitions.
Just noticed a few errors in your code. So, here is a version that compiles,
#include <htc.h>
__CONFIG (UNPROTECT & MCLRDIS & PWRTDIS & WDTDIS & INTIO & BOREN);
#define _XTAL_FREQ 4000000
void main (void)
    GPIO    = 0x00;
    CMCON    = 0x07;
    TRISIO    = 0b11111011;            // GP2 is output
    while (1){
        if (GPIO0 == 1 && GPIO1 ==0)     // if input pin 0 is high and pin 1 low then
            GPIO2 = 1;
            __delay_ms(5);
            GPIO2 = 0;
        else if (GPIO0 == 0 && GPIO1 == 1)  // if input pin 1 is high and pin 0 low then
            GPIO2 = 1;                        // loop until pin 1 is low
            __delay_ms(5);
            GPIO2 = 0;
            __delay_ms(125);
            __delay_ms(125);
            __delay_ms(125);
            __delay_ms(125);
        else
            GPIO2 = 0;
Ok so my first try (not posted here) was kinda correct. I used GPIO.1
And i see that the delay is max 125 ms or is that just a way to make shure it wont do anything else that intened?
Thanks Mike for the help .
Edit.. I almost forgot that im not going to use xtal, just internal clock (the delay time is not critical)
Im going to look in the Data sheet for the pic to get it working as I want
The config line select the internal clock.
__CONFIG (UNPROTECT & MCLRDIS & PWRTDIS & WDTDIS & [COLOR="red"]INTIO[/COLOR] & BOREN);
The delay is converted into clock cycles and 500mS is too big a number. The cycles/2 needs to fit in 16 bits.
Reason I asked is that i see the line
and I was not thinking about using a xtal.
Will it work without xtal connected?
Do i get it right when the definition is just to let the uC know the speed?
Just to be sure i have gotten the hang of it now..
The pull down / up resistor should be some where in between 1 and 10 k right?
Ok thanks for the info Bill. I was planning to use 5v as 1 but i guess i can change it.
Thats why i asked but also for future projects where I might have need for pullup or pulldown res.
EDIT
It seems that the programmer i used neede to have config bits/word programmed separately to the uC ??!?!
