resistor needed for optoisolator?
harps
hello : )
i have a 5v logic signal and wish to trigger an opto-isolator with it . i have tried an on-line calculator for working out a resistor, but need expert help to be sure.
Opto-isolator is a: dual HCPL2731 DIP8
ratings from the data sheet
Input Forward Voltage 1.4v(typical) - 1.7v(max)
i think it says 12ma input max? ( so i've gone for 8ma)
the data sheet is hereHCPL2731 Datasheet pdf - Dual Channel Low Input Current, High Gain Optocouplers - Agilent (Hewlett-Packard)
i worked it out to be 470 Ohm resistor if the desired current be 8ma.
but i could be totally wrong about the 8ma.
thanks for any help. : )
Most "5V" logic signals supply only 3.5V at 0.5mA or less.
You need to know how much actual voltage at how much actual current is provided from your digital signal.
A 470 ohm resistor in series with a 1.5V LED limits the current to (5V - 1.5V)/470= 7.4mA Which is not very bright.
Your math is ok and 8 ma is probably ok if your logic signal can supply that much. You don't say how much current you need from the output but with 8 ma drive you can get at least 20 ma of drive from the opto.
thanks uncle scrooge :)
The logic signal is from an arduino which can output 40ma max per output pin , i think it is very close to 5v , i shall check the actual voltage tomorrow when i am set up again.
i not 50 percent sure about the actual 'ma' for the opto-isolator now, i can't make out the schematic very well. The Internet shop i'm buying from is saying 20ma max on their web page , but the schematic says otherwise i think .5 min and 12 max so i thought about 8ma would be o.k.
Looks like your pin will source 4.5V at 20mA at 25degC.
thanks everyone
i think I shall purchase 360 ohm resistors when i order the opto's.
really appreciate your help.
have a nice week : )
