Arjames090686
Hi Guys,
I am new to this site and the world of electronics! I am currently in my second year of a ONC in Electrical/Electronic Engineering and start my project this year. I have kindly been given the below scenario by one of my colleagues in work and was wondering if anyone had any suggestions about how i would go about this.
I have been doing research into how Variacs work etc and also have been given a lot og Forest M Mimms notebooks which show various OP Amps and Comparators etc which is proving helpful but a few hints and tips would be great to set me on the right track.if i have not provided enough information then feel free to ask and i will endeavour to find the answers for your questions.
Spec below:
As i mentioned, i am learning and
Objective: To remotely control the output voltage from a variac. Once the required voltage has been sent the variac must track that voltage without further intervention from the host PC / PLC. The voltage can be changed by the host. The variac will then track this new voltage.
Technical Details:
Input Voltage 230VAC 50Hz
Voltage range: 10VAC to 264VAC
Resolution: 1V
Response: 3V to 5V per second.
Accuracy: ±3V around required voltage.
The controller must be powered without the need for additional bench top power supplies.
The prototype can have an analogue signal to demonstrate the control principle if it makes it easier.
The variac will be controlled from a PLC or PCI digital IO card. Both these devices will have relay output (zero volt contacts)
Up to 24 inputs and 24 outputs are available (the minimum used the better).
Custom PC / PLC software can be written by the customer to provide the desired signal’s. You will need to advise early in the development, how many I/O lines are to be used and later what the signals required are.
Wish list extras:
Display showing the variac output voltage VAC.
Cost Target: A Digital variable AC supply is approx £3000, but has a lot of extra functionality (See AC Power Supplies (AC Power Source): Compact AC Power Supply (CV/CF) PCR-M Series | KIKUSUI ELECTRONICS CORP. -Products-).
Delivery date: Project submission date.
Spec below:
Technical Details:
Resolution: 1V
Wish list extras:
