Hi people,
Well, I am a newbie. I come from the digital world, and I am pretty lost right now.
I have to build a control system.
The input is a Pressure Sensor, which gives a voltage output from 0 to 50 mV, depending on the pressure.
The outputs are some actuators (valves, which are activated with a pulse; and a motor, which also needs a pulse, something like 0.2 A for some mS)
The only Functional Logic is that, in case the pressure sensor voltage is higher than X value, these actuators should be activated (a pulse). In case the voltage is lower, deactivated (another pulse).
I checked in the internet and found a Relay Board, but I am not sure this is what I need...
Thank you very much in advance!!!!!
Best regards!!
Gabriel
Best regards!!
Gabriel
