Relay switcher
Mike_2545
Super Moderator
Ok, about 3 weeks ago my hard drive crashed and I was out of service for awhile. So I decided to make a bench power supply. I had all of the ingredients,
  • Transformers
  • Positive and negative voltage regulators
  • Capacitors
  • Kick ass retro cabinet
  • Digital volt meter
Problem is I only had the one volt meter, so I settled on a three way rotary switch to go switch between the positive and negative sides. With a twist for the middle position.
I wanted to make a switcher that would switch back and fourth between the two voltage values, like the relay ct: (below)
I thought slamming back and fourth with a regular flip flop would be a bit harsh on the digital meter, maybe I just wanted to be different.
Now I'm absolutely positive I went about this the long way round, but this is what I came up with; and for just a hobbiest I feel pretty good that I was able to do it in one evening.
Those "super-Darlington" transistors are not going to do anything. Their supply is coming from the drive line.
The circuit is far too complex for what it trying to achieve.
Draw a circuit of the voltages you are trying to measure.
Those 'super darlingtons' provide the time delay part.
Of course its far too complex, I already said that, but it works.
The circuits of the voltages I am measuring are your average lm337 & lm317 regulators
This 'mess' switches between the two supplies for the digital volt meter to read them
If you want to get a "time delay" on the rising voltage, put in a zener. The "rise time" delay you will get with two Darlingtons is less than 3v.
