Relay selection
pjshah72
I am searching for the Relay (SPDT) that can take 24VDC on coil and it switches contact from NC to NO. (output voltage on "NO" should be the same 24Vdc) Can anyone suggest me relay?
One more question, can i use the same voltage on "Common" terminal of the relay which is applied on the coil of the relay?
Please see attached diagram.
Thank you,
pjshah72
hi pj,
We need to know the current that you are switching on the relay contacts.?
With ref to your circuit drawing, it shows the relay always energised.?
E
hi pj,
E
Hi eric,
Current should be 2Amp and to keep some margin, I think 3Amp is a proper number.
Yes, when I connected 24Vdc, it will stay connected all the time, and when I disconnect 24Vdc, relay will go into the NC mode.
